I can't get my hp 6980 to print wirelessly. The bluetooth isn't enabled. How do I enable it??
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructions.
Hope this helps. Bud
Posted on Jan 27, 2009
Bluetooth enable
Bluetooth technology allows enabled devices to share information and data without having to rely on a wired connection.
To pair other Bluetooth devices with your HP Pavilion, you must first make the computer discoverable by turning on the Bluetooth antenna.
HP includes the wireless assistant to help you manage the various wireless features of your computer.
Click "Start" and type "wireless assistant" into the search box.
Click the "HP Wireless Assistant" entry in the list of results.
Locate the "Bluetooth" entry. Click the "Turn On" button in the "Bluetooth" category to enable the Bluetooth antenna in your HP Pavilion.
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01948661&printver=true - DeviceOn
Nov 28, 2013 | HP Pavilion Computers & Internet
The bluetooth for my HP is gone
Hope this helps
Oct 24, 2012 | HP 403895-001 PAVILLION DV4000 V4000...
The f12 button isn't disable the bluetooth device but when i press it the bluetooth is enabled , on the other hand the wireless light is switched on permanently equal the wireless is enabled or di
On my laptop Fn displays a certain number icons corresponding to Esc, F1, F2,F3,F4,F5,F6,F7,F8, F9 with F8 activating and deactivating the Wireless. F10 toggles the overlaid keyboard, F11 allows one to use the overlaid keyboard
There are no icons for F10, F11, and F12.
After the icon for F9, there is one for TAB, another for Space, and a last one.
If you click the last icon you open a second set (second page) where there are other icons that control other features. There is one to turn ON and OFF the BlueTooth Adapter.
Sep 10, 2012 | Computers & Internet
How to enable bluetooth on my hp pavilion dv7
link to driver if not installed alredy
if driver installed :
Check that your PC has a built-in Bluetooth device by consulting its user guide. If it does not, you'll need to buy an external receiver often referred to as a "dongle" and connect it to a spare USB port.
Ensure that your wireless and Bluetooth receiver is turned on. Touch the antenna symbol next to your PC's volume control. It will turn blue when it's on and amber when it's off.
Go to the "Control Panel" from the start menu and select "HP Wireless Assistant" if you're using XP. You'll need to go via "Network and Internet" if you're running Vista or Windows 7.
Make sure your Bluetooth adapter is enabled. If you get a warning that it's not, click on "Windows Device Manager," right-click on your Bluetooth device and select "Enable."
Go back to the "HP Wireless Assistant" window and press the "Turn on" button next to the Bluetooth icon if it's not already showing as being activated. Your Bluetooth device is now on and you're ready to connect to another enabled unit.
Jul 26, 2011 | HP Pavilion dv7-1132nr Notebook PC
How to enable bluetooth on hp pavillion laptop
Hey there,
If your particular model of HP has the bluetooth installed from the factory, turning on the wireless switch on the front left edge of the laptop enables the bluetooth, as well as the wireless LAN. A bluetooth icon should appear in your taskbar, near the clock, when bluetooth is turned on. Most of the cheaper versions of the DV6000 series do not come with the bluetooth module installed. The module can be ordered from HP Parts and installed by the end user, if they have a little computer know how. You would then download and install the bluetooth software pack that is available on HP's support website.
Hope this will help to resolve your issue with Bluethooth..
Cheers!!!!!
Vivek
Feb 14, 2010 | Computers & Internet
Hello Help me how to enable bluetooth on my Dell Vostro 1710 ?? All the drivers are supposely already instal , but still can't activate it ?? Please do help ?? Thanks
To enable it use the wireless switch on the right side, slide it to enable wireless/bluetooth device.
Hope this helps
Jan 07, 2010 | HP Mini 1035NR Notebook
Can I make this a wireless printer?
You can connect the printer via USB to a single PC or via Ethernet on a network. Though it doesn't have wireless capability built-in, you could also connect it to a wireless router or a print server for a shared wireless connection.
Dec 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Bluetooth cannot be enabled
try ... uninstall driver from "device manager",
reboot
It will probably load ok. hopefully.
let me know
Apr 12, 2009 | HP Compaq nc4200 Notebook
Bluetooth in HPTx1000
I believe there's a switch on the HP pavilion TX1000 to enable its Wireless LAN and Bluetooth.
To the right of the audio inputs and outputs is a slider switch and an LED. This one controls the wireless devices, both the Wireless LAN and Bluetooth and is blue while the wireless devices are enabled and red when they are not.
If you are using Windows Vista on your computer, you may go click on this link for instructions on how to use bluetooth with Vista.
Using Bluetooth with Vista
Sep 12, 2008 | HP Pavilion tx1000z Notebook
Wireless or Blue tooth capable
You may call HP Tech Support At toll free- 1-800-585-2494 and ask any technical question to hp support agent. you may also contact them via chat support by visiting: HP Customer service . hope this will help you better.
Aug 08, 2008 | HP Deskjet 6980 InkJet Photo Printer
152 people viewed this question
jasbo
jasbo
