Question about pawhut Pet Dog / Cat Egg Shaped Pod Sleeping Bed House - Light
Death Trap This product has been known to have caused the suffocation deaths of many cats and small dogs. There are no air/ventilation holes. When the product tips over, the animals cannot get any air. This product needs to be redesigned or taken off the market NOW !
What home remedy product I can use to keep cats & dogs out of the garden?
a gallon jug with a solution of little bleach and mostly water
Jan 29, 2015 | Pets - Others
Where does the saying raining like dogs and cats come from
Raining very heavily.
Origin
raining-cats-and-dogs.gifThis is an interesting phrase in that, although there's no definitive origin, there is a likely derivation. Before we get to that, let's get some of the fanciful proposed derivations out of the way.
The phrase isn't related to the well-known antipathy between dogs and cats, which is exemplified in the phrase 'fight like cat and dog'. Nor is the phrase in any sense literal, that is, it doesn't record an incident where cats and dogs fell from the sky. Small creatures, of the size of frogs or fish, do occasionally get carried skywards in freak weather. Impromptu involuntary flight must also happen to dogs or cats from time to time, but there's no record of groups of them being scooped up in that way and causing this phrase to be coined. Not that we need to study English meteorological records for that - it's plainly implausible.
Feb 14, 2014 | Games
Blue screen death
Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return hardware settings to default in Device Manager. Unless you have a specific reason to do so,the system resources that an individual piece of hardware is configured to use in Device Manager should be set
to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of blue screen
Sep 07, 2013 | Advent Computers & Internet
Engine overheating
old post,
vast reasons, first the macro list (pure physics)
A: engine producing too much heat.
B: cooling system failure.
C: both.!
what car, what year, what model car. gee, just a hint?
Micro:
engine timing way off, causing vast heat production.
engine running on lean side, then flogged hard.
Cat clogged.
gross misfire.
rad internal tubes, clogged, use and IR to check (ask)
bad thermostat #1 all time reason,
on 1.8L clogged, stat hosing return line (small hose and pipe)
low coolant, no, the side tank dont tell you this.
a/c consensor packed blocking air to main engine RAD.
bad water pump impeller some get eaten up by electrolysis.
loose fan belt.
fan clutch slips even hot.
if newer suz, (unsaid) electr fan death. for blow fuse to same, etc.
take car to any ASE shop, and i promise, easy discovery.
Feb 06, 2013 | Suzuki Cars & Trucks
My ps3 keeps shutting down. It is ventilated. What
If it is blinking a red light this is known as the yellow light of death (ironic i know). This is caused by the unit overheating causing the solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Feb 03, 2010 | Sony Playstation 3 (PS3) Console
My lg vu has the blue screen of death and is saying... error fatal ui dog file????? what happened and can this b fixes?
My lg cu 920 has the blue screen of death and saying... error fatal ui dog file??????what happened can this b fixes?.
Oct 09, 2009 | LG Vu CU920 Cellular Phone
3 redlights aka ring of death
HI there, This is usually caused by the system over heating. What happens is the Graphics Processing unit, Central processing unit, Produce to much heat and warp the motherboard causing the Lead free solder to crack/break looking there connections.  If you're still under the 3-year warranty please contact microsoft for Repairs...  Things to keep in mind with the 360 console would be...  Console has to be kept in an open area with good air flow and not on carpet or in a place that will slow ventilation (inclosed entertainment centers).  Power supply also needs good air flow and vents should be kept clean of dust. I hope this helps and good luck
Mar 21, 2009 | Microsoft Xbox 360 Console
I have a 1997 neon,it runs but won't idle.any suggestions?
You may have a plugged catalytic converter. When you are on the gas, the engine is basically forcing the air through, but at idle and much lower exhaust pressure, the gas pressure builds up and suffocates the engine.
It should cost around $10 to take it to a shop where they will test it for you. They drill a small hole BEFORE and then AFTER the cat and use a gauge to measure the PSI of airflow. They then weld the 2 small holes shut.
I had this happen to me with my 1995 Neon. It was very confusing until my father suggested I try the "cat" solution. Pretty neat!
Hope this cures it for ya. btw- a new "cat" should run around $200 installed.
Feb 15, 2009 | 1997 Dodge Neon
2 red ring of death
use a very small screw driver to pop the clips on the cover, be patient its a ball ache job! then try using a can of compressed air to blow dust and stuff away.
make sure its in a well ventilated area.
Mar 27, 2008 | Microsoft Xbox 360 Console
pawhut Pet Dog / Cat Egg Shaped Pod Sleeping Bed House - Light Logo
697 people viewed this question
Top pawhut Cats Experts
Ruth summersides
Tom Chichester
RANDY POWERS
Level 1 Expert
Are you a pawhut Cat Expert? Answer questions, earn points and help others
