SET TURNS OFF IMMEDIATELY AFTER BEING TURNED ON
I have a 50" MITVS50703 purchased in 1998. It was working perfectly up until 2 weeks ago. Either from the remote or by pushing the POWER button on the set---the light goes green and then in 2 seconds goes out again and the set nenver turns on--no video, no sound.
    Sergeant:
    Scholar:
  • 199 Answers
This sounds like the convergence circuit going bad. it is very common on your model. it is some bad parts overheating. in time the tv will stop comming on. a cost of repair will range around 400.00. it is a good tv and worth a repair. or the main power supply board gone faulty and needs replacement.
Posted on Jan 26, 2009
  • 4,472 Answers
Most likely this is overload protection. This tv will definitely require repair and I would recommend professional service. If you need further assistance let me know. http://direct.where2getit.com/cwc/apps/w2gi.php?template=search_new&client=mitsuservicer#?mid=174138
follow this link to locate the nearest service rep. and you can inquire with them about an estimate. also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
  • 90 Answers
I would start by unplugging the tv and waiting about 5 minutes for any capacitors to discharge. Then remove the back panel of the tv, and inspect the main circuit board. The first thing to be checked is the fuses. There will be atleast 1 or more fuses on the circuit boards, and hopefully 1 is blown. Is it DLP or rear projection?
  • Peter Castaldo
    Peter Castaldo Jan 26, 2009
    If there is a bad circuit board, it will look different. It will have a brown color in spots. Anything worse than the obvious burnt board, bad bulb, or blown fuse is really meant for a professional repair person, they have equipment to help diagnose the electronic parts. I have has tv's fixed before, and it usually costs about $250 for something relatively simple. If I can be of any more assistance, please let me know. Please remember to rate your Experts, thanks.
    Pete
    Sergeant:
  • 221 Answers
Its the problem of main board as the components getting over heated and the tv shutts off.it has to be checked with a meter to replace the faulty component.
  • 130 Answers
Try unplugging it for a bit. This happened to mine and that worked. It may also be the lamps
Hp g72-260us suddenly shuts down on battery power only
your power setting is not work perfectly going to your battery option and click that then you setting power capability.
Feb 17, 2012 | HP Audio Players & Recorders
I purchased a used 32LG3000 3 weeks ago. Worked perfectly for 2 weeks. One week ago it turned itself on in the middle of the night and now we have all types of problems. Does not respond to remote at...
This problems the tv itself have a intermittent problems in the tv Tuner signal board.That the tv board that where the tv incomming broadcasting tv signal cable plug into it.This tv problems can't be fixed,because it could be anywhere in the tv Tuner signal board parts problems itself.If u bought this tv by a dealer,reconmendation exchange it for another tv.
Aug 13, 2011 | LG 32LG30 32 in. LCD HDTV
I have a Fuji finepix j38 that is appox. 8 months old. When I turn the camera on, the lens comes out, immediately retracts, and "zoom error" comes up on the LCD. I can view pictures, but can't take any. ...
I thimk your problem is that you have sand betwin the lens mechanism and that cause the immediately retract.you can try to apply air pressure near the lens but with care
Oct 05, 2010 | Fuji Cameras
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
98 Ford Explorer wont move in reverse or overdrive
Probably low oil pressure in the transmission or worn clutches.
Mar 09, 2017 | 1998 Ford Explorer
TV Pops & turns off
There are no tubes; generally the pop happens because of high voltage. It is being shorted out and the pop is either the flyback transformer or the horizontal transistor oscillator. these two are reponsible for creating the high voltage cycle for your television; when either of them or their circuitry is shorted out you hear that "pop" which is the emergency cut off circuitry coming into play to protect the rest of the television.
May 17, 2008 | RCA Televison & Video
1998 50" Rear Projection Hitachi Model #50SBX70B--NO picture
can you see the g2 from crt sound like you list your g2 from
the flyback.i need m# plz
Mar 30, 2008 | Hitachi 57SWX20B 57" Rear Projection...
No Sound Through Speakers
Hi Jake,
If you haven't done so already, I'd try double checking the speaker wiring, you may have some exposed or badly kinked wires behind the unit.
Cheers,
Matt Coyote
Feb 20, 2008 | Car Audio & Video
You should try to do an A/C reset on this unit. You will need to power the unit down, then unplug the unit from the wall, leave it for 30 seconds, and then plug it back in. The other thing you might want to do is check your input source, if the input source is some sort of set top box, you might want to try the same with it, only leaving it for 1 whole minute. If these don't work, you probably will need to contact service.
Jan 05, 2008 | Hitachi 42V710 42" Rear Projection HDTV
Turns ON but switches OFF immediately
that happened to me about a year ago, and i think it happened after a storm. i must have sat there and turned it on at least 50x. so finally i just left it unpluged for about an like a day. pluged it back in and it worked.
Nov 04, 2006 | Kenwood XD-A75 CD Shelf System
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
