Question about Element Televison & Video
Element eldfw407 how to hook up speakers
Can I splice fans in element eldfw407 lcd to keep cool
Just place an air blower. Fan wont be sufficient.
Feb 01, 2016 | Element Televison & Video
Element eldfw407 has blue screen only does not get menu or input screenswhat would cause this
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 10, 2015 | Element Electronics 40 Class LCD HDTV -...
I have an Element FLX-2610 TV. Everything works but I have no sound. Volume is up to the max and I hear a buzzing sound.
You may have bad speakers. Have you tried hooking into the audio out ports to see if there is sound coming out from the ports. If so, then your speakers are bad ( commonly known as "blown" ). If no sound is coming from the audio out ports then the controls brd maybe bad.
Oct 16, 2013 | Element Electronics Televison & Video
Code electronics element eldfw407
HDMI white balance settings should be re-calibrated. It is a skilled work. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Apr 30, 2013 | Element Electronics FLX-2610 26 in. LCD...
Code number
hi . you could try ge brand or philips brand universal remote control in code#1173 or auto code search. maybe working your element lcd tv. good luck!
Sep 03, 2012 | Element Electronics Televison & Video
How to hook up the sound bar and subwoofer to tv
everything is hooked up correctly tp element tv
but no sound
Apr 25, 2011 | Vizio VSB210WS Soundbar
My Element LCD's volume willnot come on when I turn on the TV even if I turn it up. Do you know what causes this
Look at the on screen soud setup menu to see if the speakers are turn OFF. If it is setup OK, then try hooking up powered PC speakers to the AUDIO Line out put RCA jacks to see if you bet sound there, if you do, then the problem is in the power amp section, if not, then the problem is in the sound processing circuits.
Nov 06, 2009 | Element Electronics FLX-3211B 32 in. LCD...
I just bought a Element 32LEOQ and the sounds goes off after 15 minutes
Try hooking up the powered PC speakers to the Audio line output RCA jacks, if the sound does not cut out, then the problem is in the power amp sections that drive the speakers, it may be over heating and shut itself off, most Class D amplifier are used in the flat screen TV will shutdown if it is over heating or short circuits.
Nov 01, 2009 | Element Electronics FLX3220F 32 in. LCD TV
My amplifier puts about 36volt dc at the speaker outputs. what kan be wrong. I just kant vind the fault.
This is not a good thing. The DC current will cause the speaker ciols to heat up just like the element in a toaster. This unit requires repair. Either the outputs are shorted or the driver circuit has a problem.
DO NOT hook this up to speakers as the speakers will be damaged.
Dan
Mar 06, 2009 | Technics SUV500 2-Channel Amplifier
Televison & Video Logo
21 people viewed this question
Top Element Televison & Video Experts
Joseph Hoffmann
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
