Question about HTC Tools & Hardware - Others
Need a drive belt for portable planer hheppro/01770
Were can you buy this belt
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: powerdrive belt
I would try here and see if there is a place by you. Good luck.
http://makita.com/en-us/Modules/Service/ServiceCenters.aspx
Posted on Dec 15, 2008
  • 52 Answers
SOURCE: were can i buy a drive belt for a 1902 makita hand
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/1902
I've had really good luck with Tool Parts Direct. They send emails when something ships and are upfront about the parts they order direct from the manufacturer.
Part Number 225071-8 is $10.79 and ships in 10-14 business days.
Posted on Mar 08, 2010
Belt on my dewalt dw680 planer slips and starts smoking
If the ball bearing of the armature was getting too hot by working with too hard woods may be the bearing of the armature can melting loss the drive belt have lost a little tension by it the housing and a bearing has to replaced in that case.
Feb 10, 2016 | Dewalt DW680K 3-1/4" Planer
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Need a drive belt for a homier planner hep pro/01770
Try ebay. Don't misspell the make model etc!
Jul 07, 2014 | Makita Garden
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
How do I replace the drive belt on my dewalt planer
Hi ladyccowboy1,
The drive belt is on the side with the handle (you might already know that :>)).
Take the top off, then remove the lifting gears. Remove the side cover. You'll see the cutterhead pulley that has ridges on it to keep the belt from moving in and out. Remove the pulley.
Change your belt and reassemble.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 24, 2011 | Delta TP300 Shopmaster 12-Inch Portable...
Drive belt for planer epn 7582 n to replace a broken one
if you need a part check tool parts direct. if you have the belt, pull the side off opposite the handle that raises and lowers it. you have to roll the old belt off and then you have to roll the new one on. it will be tight and hard to do. if it isn't, there is something loose and that is not good.
Aug 31, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
Were can i buy a drive belt for a 1902 makita hand planer
Mar 07, 2010 | Makita 1902 3-1/4 inch Planer, 16000 RPM,...
Belt on delta planer
I went to Dewaltservicenet.com and looked at a parts explosion and also the instruction manual for this tool. The manual doesn't say anything about how to do it, BUT the explosion is good quality and should guide you thru replacement. Please let me know if I can help further and if I answered your question would you please rate it accordingly Thank you.
May 15, 2009 | Delta TP305 12 - 1/2" Portable Planer
Tools & Hardware - Others Logo
779 people viewed this question
Top HTC Tools & Hardware - Others Experts
john h
Are you a HTC Tool and Hardware - Other Expert? Answer questions, earn points and help others
