Question about Cycling
Stamina 4655 manual - Cycling
I have an AprilAire 550A with bad humidistat. Can't find replacement. Got a 550 but wiring not right. Not sure what to do!
I believe they just updated model number descriptions. The basic design of that humidifier hasn't changed much over the years. I would go to their website and look for the one that is simiar to your model and get the humidistat for it. They are pretty basic devices as far as what the humidistats do. 24v power and common
Feb 23, 2013 | Aprilaire Humidifiers
Stamina/Speed Switch In Windows 7
Page 104 of the manual says you must reboot between switch changes to install the change.
The manual is here
https://docs.sony.com/release/VGNSZ400_UG_US_F.pdf
Nov 28, 2012 | Sony VAIO VGN-SZ440 Notebook
Stamina 300 treadmill
RUN the software calibration for diagnose, and troubleshooting and fix it.
in according with the instruction manual schedule maintenance.
if you do not have instr.manual go for free: www.iconservice.com or www.fitness.manualsonline.com
God bless you
May 08, 2012 | Stamina Products Stamina 451002 Treadmill
I have a Stamina 4700R magnetic resistance recumbant bike. I'm looking for a place or website to buy plastic caps for the feet, a manual, and possibly the Stamina In touch fitness monitor. Where can I...
This is the main SITE for your unit, yet it appears to be an older unit, you can browse thru and maybe you'll find something similar to what you have and use that manual instead of the one you have. It probably won't be very much different from yours. As for parts, there are links on the page to find what you need.
Hope this is of help, Please rate and comment, Thank You
Joe
Sep 01, 2011 | Stamina Products Cycling
Aprilaire manual humcontrol 4655 hum 560 .when control clicks works fine.move dial to outside temp never works changed 4655 twice i have 28\r\nvolts ac all the time
When humidistat is at ouside temperature that may be a lower humidity setting than is in your home. Doesn't sound like there is a problem. If it is too dry in home you can set it above ouside temp to turn on. The ouside temp setting is estimate that you will not get condensation on windows.
Jan 17, 2011 | Aprilaire 550 Humidifier
No manual for Medicarn body slimmer
Try ringing Medicarn customer services in Sheffield.
01142329006
Jan 13, 2010 | Stamina Products Stamina Instride Plus...
I need a manual on my stamina r360 recumbent bike how to clear the settings on the in touch monitor
If this is the same Stamina R360 as I have, you just hold down the orange oval button (labeled: MODE) until you hear a beep. This resets the readings.
Feb 28, 2009 | Stamina Products Stamina Pro 5300 Silent...
Cycling Logo
43 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
