Question about Canon PowerShot A75 Digital Camera
My camera is not working
The zoom started to go blurry and was not working properly and then it tirned itself off . So now when i turn it on the start up screen comes on with canon but then beeps and the screen goes blank with E18 in the left hand corner. I have lost my manual and have no idea what it means . please help ?
    Sniper:
  • 60 Answers
Hi, The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started receiving E18 errors. Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode. 1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on. 2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine. 3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works. 4) Try forcing the camera lens: Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on. If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on. Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving. this is the final solution.. but you need to open th ecam. follow th elink if abov esolution doent help you. http://www.fixya.com/support/t102982-e_18_problem regards sreejith
Posted on Jul 18, 2007
    Sergeant:
  • 274 Answers
The lens sticks when it comes out and you get an error E18 and black screen. Looks like Canon is not very good at customer service either considerring all the complaints I read. Read more here: http://www.e18error.com/ Cannon should repair it for free if under warrentee.
6ya staff
SOURCE:
After inserted recharged battery, the LCD screen is blurry. Pictures taken is also blurry. Camera turns off itself when using the " T " zoom button PLS HELP
Make sure you hold the camera steady .It has been my experience that if you hands arent steady your going to get a blurry pictures and also it will look blurry in the LCD window.
Jan 28, 2011 | Olympus Camera Case For Olympus Fe-4030...
JVC Digital Camera focus
Did it work before? If so then it sounds like the focus motor/screw jack has failed and needs replacing. With some JVCs you can replace the whole lens system and a new one will re-calibrate itself, but I'd have to check on this model.
Feb 07, 2010 | JVC GR-D770 Camcorder
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Jun 20, 2009 | Olympus FE-230 Digital Camera
Zoom not working - Screen goes blue and codes 1e13 3403
Was not fixed. Do not have this specific camera.. Is a different Olympus.
Jun 16, 2009 | Olympus Camedia C-50 Zoom Digital Camera
Camera turns itself off immediately even though it is fully charged
are you using rechargeable batterys or cheap ones
you have to get batteries specifcly designed for digital cameras or they wont power the camera properly.. try using different batteries !!
May 22, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Olympus FE-280 not working properly
the lens could be the problem.. probably need to send to repair before the warranty runs out
Aug 28, 2008 | Olympus FE-280 Digital Camera
Blurry pictures!! help!
If it's making noise when turned on you are experiencing trouble with the lens. If you send it into repairs they can fix that. Give them a call at 800-706-2534 option 2.
Apr 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Olympus FE280
I just had the exact same problems today, I found this post by searching the Internet for solutions. =) By fiddling around I found a solution that worked for me. If you hold the lens once they're "down" as they are spazzing out, gently but firmly keep your grip so that the lens is flat against the rest of the camera as it tries to expand forward. Keep holding and wait until the camera turns off by itself. Then turn it back on, and voila! It worked for me, the blurriness was gone and I could zoom again like normal.
Mar 29, 2008 | Olympus FE-280 Digital Camera
Blurry pictures, and zoom not working
yeah the same thing happened to my camera last month and I just went to the repair place yesterday. Apprently Casio products arent that sturdy so if they get hit the lens can become misalligned and you can't fix it yourself. A new lens is more than the camera itself so if you have to get a new camera I wouldnt suggest another casio one. Good luck.
Aug 13, 2007 | Casio Exilim EX-S600 Digital Camera
Canon PowerShot A75 Digital Camera Logo
90 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
