Question about Brookstone Automatic Wine Opener
Replace the cork screw
Replace the court screw in model SKU 606368
My electric wine opener stopped working with a cork in it
Battery has gone flat or it has overloaded the cork screw motor and you will have to cut the old cork off. Try again once changed the battery
Sep 21, 2017 | Home
How can I replace a pig tail on a bottle opener
The following seems to work, but might be tough if you don't drink the wine first. http://www.youtube.com/watch?v=5Y82j3R7tXw
Jul 02, 2014 | Home
Not functioning ! Cork screw not inserting to
Hi rich, My name is John. Welcome to FixYa. Turn the screw one turn counter clockwise while pushing inward. Thanks for choosing FixYa....John
Dec 05, 2010 | Northstar Air Tools & Compressors
I have a Homelite Super XL chain saw model 100454. Gas leaking around cap when turned on side to cut. Cork gasket look fine and surface is flat where cap in screwed on. Any help?
Just because that cork gasket "looks fine" does not mean it is working properly. Replace it with a polypropylene (oil and gas resistant rubber) gasket. That will clear up your fuel leak problem.
Dec 15, 2009 | Garden
My machine drinds coffee in large pieces.It doesnt grind when I set the regulator on 6 or 7 and appears message "Coffee beans is empty"
HI
One possible problem is your grinder has become separated, so your beans are not feeding equally. The beans are going to one side of the burrs and are ground into big chunks. If you remove the beans in the bean hopper and look down on the grinder. If the cork screw is off to one side that is your problem. Of you can move the cork screw from side to side you need to replace your grinder in either case.
Oct 12, 2009 | Saeco Magic Comfort Plus Espresso Machine
How do i replace a clutch on a 2002 yz 125
Drain the transmission oil, then remove the side cover that is on the opposite side from the rear drive sprocket. You should see the clutch at that point. Remove the cover screws (count the turns) and start pulling disks and metal plates out of the hub--keep track of the order of removal. You need to replace only the cork faced plates, the metal disks hardly ever wear out. Count how many cork plates you need to purchase. There may be competition replacements that have better 'bite', but are not as smooth to operate. Be sure to replace with fresh oil when you are done and use a new gasket for the cover. Check the release rod in the center of the hub for straightness. Good luck!
Sep 18, 2009 | 2003 Yamaha YZ 125
Maytag dryer making drum making a funny sound when it goes around and when i opened the front a small piece of cork was on the bottom
hi thanks for the question that small piece ov cork is part of the front bearing purchase the front bearing kit. not much $ to replace. tilt dryer towards the wall disconnect power sourc,e remove 2 screws on front panel .to remove the front bearing . 4 5/16 screws 2 each side remove keeping the drum steady you will see the worn part you must drill out or file down the rivets that hold the cork and teflon bearing . remove & replace .thanks the appliance doc
Sep 28, 2008 | Maytag Dryers
Brookstone Automatic Wine Opener Logo
74 people viewed this question
Top Brookstone Electronics - Others Experts
Are you a Brookstone Electronics - Other Expert? Answer questions, earn points and help others
