Question about Acer AL1717 17" LCD Monitor
How to remove the base from the monitor
I have installed the acer monitor base and the monitor.. but i don't know how to remove the base from the monitor.. please help me....
  • 1 more comment
  • ANIL BABU Apr 25, 2008
    I HAV TRIED LOT 2 REMOVE BASE BUT ITS TIGHT AND CLIPS ALSO SEEMS TO BE MORE TIGHT I DONT KNOW WAT 2 DO WITHIT........
  • murph0613 Jul 02, 2008
    I'm not just looking to remove the flat part of the base that the monitor rests on, but also the support arm that goes from the monitor to the base, so that I can wall mount the monitor. Any ideas?
  • hughk Aug 06, 2008
    Base is very firmly attached. Presumably "clips" referred to in previous answer are plastic sort of arms with ledges which on pushung together latches on to base ? there are 4 ? (two at ends, 2 on sides ?): how to release all at same time with only 2 hands ? What role does metal clip in centre play ?: (it does not seem to hold anything, but can be moved a little with screwdriver
For monitor or TV bases that have four clips, I found if two people each take two opposite clips, and use thumbs to push in the clips, we can pop the base off fairly easily. It is impossible with one person, since thumb and forefinger can't exert sufficient pressure on the clips.
Posted on Aug 19, 2008
I need to wall mount this also, i found away. Forget the base, that can stay on coz its attached to the arm. Concentrate on the arm. Where its attached to the monitor, pull the cover off, it comes off easy. Then you'll see to bolts either side. Take them off, and the washers. Below them you'll see 3 screws each side, just take the 3 from the left off, then it all comes out, put the 3 back in, put the black cover back on, you have the complete stand removed.
Posted on Jul 31, 2010
Http://forum.ncix.com/forums/index.php?mode=showthread&forum=102&threadid=1018603&pagenumber=1&product_id=16517&subpage=1
Posted on Dec 01, 2007
  • 32 Answers
Normally once the base is on its on forever. But you should see little clips that the base uses to latch onto the monitor. You can use a flathead screwdriver and bend the clips inward till the base pops off. Still will be hard though to remove the base. Seems they made that base to stay on.
Posted on Jul 19, 2007
Gfjhguj
Posted on Feb 15, 2008
2 Suggested Answers
freetek
  • 5569 Answers
SOURCE: acer p221w monitor removing base
Since you have surely looked, it isn't held on with exposed screws.
Check to make sure that the rounded area that allows tilting is not part of the case but appears to be separable.
Most that are removable are held by a tongue and a fairly obvious release tab.
if you can't remove the base, just place the monitor in the carton on good padding and upside down.
Fill and cushion the sides well, mark the carton with 'This side up' and an arrow and hope there are no malicious handlers on the trip.
I've shipped numerous monitors of different sizes and types and have lost none of them to shipping damage.
Posted on Aug 08, 2008
Has my integrated video failed on my acer aspire am1100-b1401b?
Make sure your Acer works with a different monitor. Check Device Manager in the Windows Control panel and maybe update the monitor/graphics card driver.
Feb 02, 2018 | Acer Aspire Computers & Internet
Can't install base on acer monitor
I, too, struggled with the same issue; however, after a fairly exhaustive search of the Internet, I came across a review that provided the answer: Attach the base to the monitor as you have been doing, but this time, place both base and monitor on the floor--while the base is still flimsily attached to the monitor--and then push down on the monitor. It will secure itself in place. It may seem like you are going to break it, but you won't. It requires little pressure--far, far less than the way we have heretofore been trying to push or jam the base into the monitor. Again, the key is to place the base and monitor (upright position) on the floor, and gently but forcefully push down on the monitor, using both hands, one astride each corner of the monitor.
Jun 02, 2012 | Acer Computers & Internet
Taking stand off screen
The base can be removed by pressing the tab on the back of the stand. I do not think that the actual "neck" of the stand can be removed.
I found a manual here (has a few helpful diagrams): http://www.retrevo.com/support/Acer-X223W-Monitors-manual/id/23224ci553/t/2/
Mar 01, 2011 | Acer 22" X223w LCD Monitor
I have an Acer monitor Mod. X221W and I cannot manage to tilt it in any manner. Can you help please? Alfred Portelli Malta
Place your left hand on the bottom of the monitor and your right hand on the top of the monitor.
Holding onto the top and the bottom of the monitor.
While holding the base level, GENTLY push your left hand away and bring your right hand forward.
To tilt monitor backward bring left hand towards you and push right hand away.
Jan 29, 2011 | Acer Computers & Internet
Tilt new monitor???
mcdevito75 here, I also have an Acer and it Doesn't tilt, that doesn't mean yours won"t, try to hold the monitor by the top and simply try to tilit it while makeing sure the base stays flat on the desk, (table) don"t force anything. Also look for any kind of screw, or handle connected to the base (bottom) or near bottom of back of monitor. Hope this helps. Oh! also check the manual that came with the monitor, mine has no mention of tilt. Sorry.
Jan 18, 2009 | Acer X191WSD Monitor
Acer 1717 monitor- removal of base
At the base you want to remove - in order to pack the monitor - if you se at the rear left and right there are a tiny opening about 3 cm long,put inside a screw driver and it will open very easly the plastic cover.Then inside there are four screws,two on each side,remove them and the arm of the screen will be dis-attached.
Dec 21, 2008 | Acer Al2416WD LCD Monitor
MONITOR ACER AL1716
1. Unplug the AC power cord to make sure the power is off.
turn the monitor upside down, you need 2 people for this.
2. Pull the 4 hooks on bottom side of the base and hold.
3. Separate the monitor and base.
Nov 05, 2008 | Acer AL1716 17" LCD Monitor
Acer p221w monitor removing base
Aug 06, 2008 | Gateway FPD2275W LCD Monitor
Disassembly for shipping
As per page 4 of the User's Manual from Acer:
Detaching the Monitor
If you need to repackage the monitor, please separate the monitor and base, and restore them to
the carton. To detach the monitor:
3. Separate the monitor and base and put them into carton.
Jun 19, 2008 | Acer AL1716B 17" LCD Monitor
Acer AL1717 17" LCD Monitor Logo
6,008 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
