Question about Samsung Washing Machines
Turn off water filter light on SRF731GDLS - Samsung Washing Machines
  • Samsung Master
  • 17,130 Answers
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Posted on Jan 21, 2013
How do I change water filter
Hello Anita;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number, so I am going to have to tell you where the water filter might be.
1.) On the lower, front bottom grill or toe plate, in the center there is a round hole. In this hole is your water filter. Grab the end of the cylinder and turn 1/4 turn counter clock wise and pull out. There will be some water in the filter. Slide the end cap off the old filter and slide it back on the new filter. Insert the new filter, push in and turn 1/4 turn clockwise.
2.) In the upper back right hand corner of your refrigerator section is where your water filter is located. There is a plastic cover plate around it, but you can still see the bottom of the filter canister. Reach in and turn the bottom of the filter 1/4 turn counter clockwise and remove. Insert the new water filter and turn 1/4 turn clockwise.
After installing a new filter, there is air in the filter. Run your water dispenser until a steady flow of water come out. You will get air & water spurting out.
If you only have a ice maker, you will have to manually cycle your ice maker until it fills.
The water filter change light is not tied into anything in your unit. It is like a egg timer. Even when the indicator light indicates to change you water filter, you only change your water filter when either the water coming out of the water dispenser is slow or you are getting small ice cubes.
Nov 23, 2014 | Kenmore Refrigerators
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
Filter light will not turn off
Resetting your Refrigerator filter indicator light after changing your water filter
Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Nov 11, 2012 | GE PFSS9PKy Refrirator
Where is the water filter located and how do i replace it.
The water filter is located in the fresh food or fridge side of the appliance, at the rear - in the upper right hand corner.
To change the filter, open the fridge door, clear the top shelf and grasp the filter. All that is needed is to turn the filter to the left about a 1/4 turn for it to drop down. A few drops of water may spill onto the shelf. To install a replacement, remove the protective cover (shown as a red cap above), and position under opening for filter. Gently push upward while turning the filter to the right. The filter will pop in, and as you turn about 1/4 of the way around, it will be drawn up a small amount until seated. At this point it will no longer turn any further.
More info about the filter is below (taken from the manual).
Please rate this reply - thanks!
The water "Filter Indicator" light
• "Filter Indicator" light lets you know when it is time to change your water filter cartridge. The light
will change from green to orange. This tells you that it is almost time to change the current cartridge.
It is recommended that you replace the cartridge when the light changes to red. (see "Install the water filter" section for more information)
• If you install water filter, throw away the first six glassfulls of water filter, or until water flows clearly to flush impurities in the water supply system.
Using the dispenser without the water filter
• You can not use the water and ice dispenser without a water filter cartridge because the water line
blocks at water supply.
Ordering replacement filters
• To order more water filter cartridges, call 1-800-SAMSUNG and ask for accessory Part # DA29-
00003A or contact your authorized Samsung dealer.
Jan 04, 2011 | Samsung RS265LABP Side by Side...
Where is the filter located in the refrigerator?
1. Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
2. Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill
3. Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
4. Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
5. Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Jan 03, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Water tastes funny
if there filter was not properly installed you would not have any water at the door.
you do not need to turn the water supply off to change the filter.
you should be able to push the filter light for three seconds,they do not turn off they just change color
May 28, 2010 | Samsung RF265AA Bottom Freezer French Door...
I changed my water filter and now i need to turn out the filter warning light.
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER
indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
Please rate me!
Thanks, Sea Breeze
Mar 22, 2010 | Maytag MZD2766GES Side by Side...
Maytag msd2454gr refrigerator how turn filter light off after replacing filter?
FILTER
Nov 23, 2009 | Maytag MSD2454G Side by Side Refrigerator
HOW TO TURN OFF THE "CHANGE WATER FILTER LIGHT"
Press light and lock and hold until light blinks release and the light will go out
May 02, 2009 | Maytag Refrigerators
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
