Question about Samsung WF410ANR Washer
Wf410 drain pump won't drain
Drain pump makes a horrible clicking noise and won't drain
2 Suggested Answers
  • 6277 Answers
SOURCE: i have a samsung front
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 19, 2011
Enter service mode, GE GTWN5650FWS washing machine. won't spin or agitate...just makes clicking noise. drain pump works. timer counts down.can I check the transmission operation by putting mac
NOT SURE WHAT UR MACHINE WILL DO IN SERVICE MODE BUT DOUBT IT CHECKS TRANNY? THE LIKELY CULPRIT IN UR CASE MAY BE A DEFECTIVE DOOR SWITCH? OR WORN MOTOR COUPLER ( BETWEEN TRANNY AND MOTOR) DOUBT ITS UR TRANNY?
Sep 26, 2014 | Washing Machines
Washer won't drain and spin
Drain pump is cloged. What kind of washer is it . and you said stacked and laundry center. stacked is 2 seperate units and laundry center is one whole unit with both so whatcha got?
Feb 17, 2013 | Frigidaire Washing Machines
The washer broke filled with water and won't drain
see this causes and fix it. God bless you
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Sep 28, 2012 | Kenmore Washing Machines
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Got an E04 messege (not the first). Set the washer to drain and it makes a horrible noise. Water won't drain out. Some E04's in the past have been accompanied by a rubber burning smell, but not...
The problem maybe the pressure switch if you have a multimeter check for any electrical issues if there is no reading your pressure switch needs to be replaced
Jun 30, 2011 | Bosch WFMC2100UC Nexxt Essence Washer
1999 Dodge Ram Conversion Van won't start. After many attempts the battery finally died but before it did it was making a clicking noise when we tried to start it. My husband saw a spark under the...
I hope that you have disconnected the battery fire could happen relay click's but will stick at drain could be the fuel pump you hear with the continuse click you might have a shorted starter.I think thats the first place to start.A bad ignition switch will cause this to happen sometimes?
Jan 11, 2018 | 1999 Dodge Ram
Washer is making a horrible sound while draining water from tub
if horrible sound is while drainpump is draining but before washer starts to spin either obstruction in drain pump or impellar on pump is bad and the complete pump needs replaced... if noise is while spinning the spider support is cracked which is very exstensive repair and dont reccomend repairing unless you have a couple of hours for dissasembley and reassembley...
Jan 24, 2011 | Samsung WF337AA Front Load Washer
Makes a horrible noise when it is draining
Either something stuck in the pump or the pump bearings need lubricating. It is easy to remove buy tipping the machine back at 45 degrees, the pump is under right front and is removed by turning anticlockwise.
Apr 19, 2010 | Fisher and Paykel IWL12 Top Load Washer
MAKES HORRIBLE NOISE AT THE START, SEEMS TO WORK OK OTHERWISE
The first step in a dishwasher's program cycle is activating the drain pump. If there are obstructing objects in the impeller it could make noise, also if the drain pump's bearings/motor is damaged. I don't know what you meant by taking out bottom part, maybe it was the drain pump you checked?
If you didn't this is normally an easily accessible component, when you have it out you can also check that the impeller rotates freely and that it feels and sounds ok in the bearings.
Maybe there is a possibility to attach a sound file here, it would help to diagnose the problem.
May 22, 2009 | Maytag MDB7100AWB Dishwasher
Samsung WF410ANR Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
