This is our house heater it is. Blowing cold air only o; . Does anybody have any suggestions on how to fix it.? Please help it is freezing
  • carminevalenti Jan 21, 2013
    it looks like a gas heater check the pilot light . really need to know if its gas oil or electric get back to me please
If its electric not gas check the main heat fuse in main breaker box . if ok check out by the heat pump outside breaker. than pull off the front panel with power off check the main 220 volt main wires usally thick black with big wire nuts make sure that they are connected well .in the future its always wise to check heat at least twice a year and let it run for about ten mmin let me !!
Posted on Jan 21, 2013
  • 189 Answers
SOURCE: The Heater is only blowing cold air
I would need a lot more info. if this is a natural gas furnace you may have a bad hot surface ignitor
Posted on Mar 28, 2009
  • 232 Answers
SOURCE: my heater works fine when its a little cold,when
do not adjust your gas pressure without an manometer or if you dont know what you are doing could be very dangerous. Roll out switches are manual reset if you have an open roll out on a Goodman furnace you probably have a cracked heatexchanger, get a qualified technician out there asap
Posted on Oct 07, 2009
Testimonial: "thanks for answering my question.your not the only one who told me that i was needing more than one persons opinion"
  • 79 Answers
SOURCE: gas heater doesn't stay on longer than 5 minutes.
It sounds to me that your air flow is restricted somewhere. The first thing to check is your air filter. If that gets real dirty your restricted air flow will cause the hi-limit(hi temperature limit switch) in your heat exchanger compartment to over heat and open up your gas valve electrical circuit,thus, shutting off the gas to your burners. After the hi-limit switch cools down the furnace will go back to heating again then it will overheat again(you get the picture?) If it keeps cycling on and off like that the house will never get warm if it is cold outside. If your air filter is reasonably clean(you should be able to see light thru it easily) then the secondary heat exchanger could also be dirty, this is located above the indoor fan housing, you would need to pull the indoor blower assembly out of the furnace and look up above. The secondary heat exchanger looks similar to a radiator will fins. You can use a medium stiff plastic brush to brush the dirt,hair, whatever off of it. Another problem spot would be the cooling evaporator coil (if you have central airconditioning) located most likely above the furnace in the plenum(if your furnace is in a basement). This usually is difficult to access if an access cover wasn't installed when the airconditioning was installed. I would recommend an experience service tech to clean it for you. Also make sure all you supply air registers and return air registers are open . These are the things I would check first. Good luck!!
Posted on Nov 20, 2009
  • 767 Answers
SOURCE: The floor vents in our house are blowing cold air
If the furnace is running and the registers are blowing cold air you have a problem with the furnace. Check to be sure the pilot lite is lite if this is a standing pilot, if not check to see if there is a flash code in the site hole in the bottom blower door of the furnace. Be sure the thermostat is set to heat and turned up.
Posted on Jan 02, 2010
  • 185 Answers
SOURCE: DAEWOO MATIZ 800CC 1999 HEATER BLOWING COLD AIR
Or you need anitfreeze.
Or your thermostat is shot. Both are easy fixes.
Try the antifreeze, first,check and top off.
and if teh problem persists, check and repalce the thermostat.
Posted on Feb 02, 2010
Overheating
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Jan 30, 2012 | 2003 Chrysler PT Cruiser
Why would my heater blow out cool air when sitting still and then hot air when going down the road and then it's not all that hot
Try flushing or blowing high pressure air through the heater core lines. its sludge build up and need to be flushed through heater core only. check antifreeze fluid level. only put in straight antifreeze, do not mix. most people do not know what mixture should be, so be safe and add straight, it will not hurt it, i run 100% straight antifreeze and never had a problem or worry about it ever freezing and cracking my block, heads or radiator cracking.
Jan 29, 2012 | 2001 Daewoo Nubira
I have a 2002 Olds Alero GL my heater is not working and car overheats peoriodically losing antifreeze, please help freezing in Montana
Engine Overheats and heater blowing cold? http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Jan 20, 2012 | 2002 Oldsmobile Alero
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Sep 05, 2011 | 2007 Suzuki SX4
My is heat is not work?My car is blowing cold air instead of hot air, I have a brand new heater core,the thermostat is not sticking,I got anti-freeze in it,It's getting cold in I need heat.Please help me
first feel the heater core hoses see if both are hot if so then your problem is in the blend air door must be stuck on cold. is your blower motor blowing cold air if not your blower motor might be the problem. the blend air door is down by the blower motor.
Nov 17, 2010 | 1995 Oldsmobile Cutlass Supreme
1998 Jeep Wrangler not blowing hot air. Fan is blowing cold air. Suggestions?
your heater hose or heater core could be plug, or your flap that opens inside of the heater housing may not be opening like it should. It operates off a vacum line, check all your vacum lines going into your heater housing.
good luck
Dec 09, 2009 | 1998 Jeep Wrangler
Heater blowing hot even after changing bulkhead valve no air-con
Theres a door under the dash that directs air over the heater core if it is broken then you will not get heat but you will still have a/c.To fix it you will have to take dash apart.
please rate my answer if satisfied
Jul 03, 2009 | 1999 Ford Taurus
No hot air & sometimes no air at all
my 2000 dodge caravan heat sometime working sometime not working
Oct 17, 2008 | 2000 Dodge Caravan
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
