Question about Samsung 906BW LCD Monitor
Waves I just bought this monitor and it is brand new out of the box. I am using this monitor with a mac mini. I constantly have "waves" streaming from the bottom to the top of of the screen. I have tried adjusting settings and nothing works. I know that sometimes a tv can causes this so I turned off all electrical devices and it still continues. Any suggestions?
  • Daniel Hoover Jul 19, 2007
    Thanks for the help. I unplugged the cables and plugged them back in and it solved the problem. I thought I had them tight the first time but I guess not. Thanks again for your help.
    Brigadier General:
  • 6,966 Answers
Hi hoovs, Waves streaming normally comes from the 60 cycles hum of the AC mains. Sometimes this is caused by poor or loose grounding in the video cable or at times a weak or defective capacitor in the power supply of the monitor or at times low voltage supply to the monitor. If after checking your cables (both power and video) are not loose and are snugly fitted to their connection points and you still get the waves, then you are probably better off returning the unit for replacement. Another thing you can check is if the monitor is getting enough power. If the monitor's power supply is rated 100~240 VAC, then it should work out ok. If it's got a 240 rating and you are using it in 110, then the monitor is not getting enough juice which may cause the waves. On rare occasion, waves may be eliminated by simply plugging in the AC plug of your monitor the other way around. Hope this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 18, 2007
I ran into the same problem with this moniter. I am running it as a secondary moniter off of my laptop and I tightened the connections and the waves went away a little but were still noticable. So I went back to the store I bought it from and exchanged it for another and got back to my house and it still had the same problem. I then decided to plug it into a different outlet from my laptop and speakers and it works perfectly, no waves or any problems at all.
Posted on Aug 07, 2007
SOURCE:
My Monitor has impulse waves.
It may be the DC filter caps in the power supply going bad, that will be the first place to look. See failed ACER and other monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 24, 2010 | Acer AL1916W 19" LCD Monitor
I hold an LG 22inch LCD monitor. I can see waves on my monitor not sure what is causing the waves.. I have moved my speakers to down rack of my comp table.. but still i am getting.. Please help me on how...
may be a problem with your motherboard connector. Try connecting the monitor using another comp and check for the waves. But before this, try to reinstall your display driver.
Feb 24, 2010 | LG Flatron L1710S 17" LCD Monitor
I am facing blurry waves on my new samsung lcd monitor sometimes these waves are strong and somes times get weak also very visible on same color background like blue and black background, these waves...
anything nearby causing electromagnetic interference...anything with a motor, speakers near monitor..
Don't forget to rate the advice!
http://www.aa1consulting.com
Jul 28, 2009 | Computers & Internet
On my monitor it is showing some waves... picture is not clear.. showing some lines(less darken)
If it is a flat screen monitor: you should try different monitor resolutions and refresh rates. Specifically, you should set your resolution and refresh rate to the specifications set by Sony. You can also use the "detect displays" button in the "display" system preferences.
If it is a CRT: Try the above, but also try "degaussing" your monitor. This is a command on the monitor itself, and it's location depends on the brand / model. turn on the On Screen Display menu and look around for it.
Jul 12, 2009 | Computers & Internet
Waves on new Polaroid LCD 42 inch screen
try a different signal source, if its still a prob return it.
Dec 02, 2008 | Televison & Video
Nebulizers problem
There are two main types of nebulizers: jet and ultrasonic devices. Jet nebulizers form droplets by using a compressor to deliver a pressurized jet stream of air down a narrow tube and through an opening. This creates a vacuum (through the Venturi effect), thus drawing liquid from a reservoir. The resultant small droplets of liquid are propelled out of the machine by the continued jet stream. Ultrasonic nebulizers produce aerosolized droplets using high-frequency sound waves generated by a special crystal. Liquid drug is usually delivered to the crystal, where it forms a thin layer. Electricity excites the crystals, causing them to vibrate at extremely high frequency. This vibration forces the thin liquid layer through an adjacent mesh, creating a fine mist. Droplet size varies with the frequency of the sound waves created by the vibrating crystals.
Aug 27, 2008 | Cardinal Airlife Brand Modudose 5 Ml Unit...
Samsung monitor randomly flashes black
> brand-new out-of-the-box
Presumably, it has a "warranty".
So, take it back to where you bought it, and demonstrate the problem to them, and make them repair/replace it, under warranty.
Sep 21, 2007 | Samsung SyncMaster 214T Monitor
"Waves" generating from the right of the screen.
It's power distortion. If you move the monitor away from the pc, the waves will stop. It's magnetic distortion causing this interference. Your monitor is fine.
Jul 05, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Faulty screen
You might need to replace the surface mount capacitors. measure the ESR on them, the higher it is, the more likely you are to get ripples. If this doesn't say much to you, take it to a lab. Use the warranty if you have it offcourse. Good luck
May 05, 2006 | HP D5060A (White) 14 in. Flat Panel LCD...
Samsung 906BW LCD Monitor Logo
802 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
