Question about Motorsports
Change power steering on ford 2001 escort - Motorsports
  • 3,103 Answers
What part of it..pump, rack and pinion..what..check with parts store for a printout of exact proceedure..
Posted on Dec 09, 2013
I have a 2001 ford focus zx2 and there is a noise coming from the power steering pump area is it hard to change?
First check the level of fluid in the pump, could be low. If not replacing it is not hard depending on experience, but for around $60 a mechanic should be able to fix it.
Mar 06, 2011 | 2001 Ford Escort ZX2
Cannot find belt tensioner on 2001 ford escort
  • Locate the serpentine belt tensioner on the front of the engine. The belt tensioner on the 2001 Ford Escort is located directly under the power steering pump and above the air conditioner pump. The belt tensioner has a 17 mm bolt head in the center of the pulley.
  • Nov 20, 2010 | 2001 Ford Escort ZX2
    I have a 1995 ford escort and very hard steering, where is the power steering to check fluid or change the pump
    The power steering fluid resivoir is located on the right hand fender up front under the hood. The pump is mounted below the altenator on the front side of the engine. The lines go down the right side of engine compartment to the power steering rack located at the bottom center behind the engine. Hope this helps, let me know.
    Jun 14, 2010 | 1995 Ford Escort
    Need 2001 ford escort zx2 DOHC engine information, belt diagrams
    The tensioner is between the a/c compressor and crank pulley, below the power steering pump. Use a 13 mm wrench to 'tighten' the bolt in the center of the pulley and it'll move to release tension off the belt.
    Jan 25, 2010 | 2001 Ford Escort ZX2
    My horn does not work changed fuse, still nothing
    test for power(using a voltmeter) at the horn's connectors while having another person press on the horn. If there is power, replace the horn!! If not, check the steering wheel, the horn switch may need replacement or repair. Hopefully this helps
    Jul 28, 2009 | 2001 Ford Escort ZX2
    2001 ford escort, has a catch in both Directions when steering
    check for low power steer. fluid,loose pow.steer.drive belt,defect.steering gear,
    Mar 06, 2009 | 2000 Ford Escort
    Leaking power steering fluid
    u might need a power streering pump or a new line i have to replace my line there like 30 but the pump is like 110 its not to bad though
    Jan 05, 2009 | 2001 Ford Escort ZX2
    What's the minimum cost to fix a 2001 ford escort power steering leak?
    There's always Lucas power steering stop leak, but personally I'd prefer to fix leak properly.
    2001 escort van power steering pump
    don't know much about the vans but on the zxw the pump will not leak on the brakes.
    Oct 04, 2008 | 2001 Ford Escort ZX2
    Motorsports Logo
    82 people viewed this question
    Top Motorsports Experts
    chuck ringwood
    chuck ringwood
    Jim Rus
    Jim Rus
    Steve P
    Steve P
    Are you a Motorsport Expert? Answer questions, earn points and help others
