Question about Grohe Plumbing
I need to replace the washers on a 21 184 centerset grohe faucet
How do I remove the handles to replace the washers?
  • 659 Answers
SOURCE: trying to remove handles on grohe 31054000
I couldn't find the number you have on the Grohe website so I have included a link to their website. Just find your model and it will give you many different options for manuals. Hopefully this will give you the information you are needing.
http://www.grohecatalog.com/category/1/
Posted on Apr 12, 2009
  • 52 Answers
SOURCE: How do I remove Grohe facet handles to get at washers?
I NEED A PIC BUT TRY TO FIND A COVER LIKE THE PRODUCT BRAND JUST A GESS
Posted on Jul 04, 2009
miket756
  • 2702 Answers
SOURCE: my Grohe kitchen faucet leaks in the "Cold" off
it could just be a washer leaking you need to strip it out anyhow to find the fault so fit a new washer when putting it all back in
Posted on Nov 28, 2010
Dplumber
  • 119 Answers
SOURCE: How do you remove the handle son a Grohe two-handl...
Pull the handles straight out of the faucet. use both hands to pull back on the hand while wiggling it left and right just a little at a time. Eventually it will pull off.
Posted on Dec 12, 2010
  • 17 Answers
SOURCE: Delta 2555-216 Victorian Double-Handle Centerset
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Posted on Sep 01, 2011
What causes grohe tenso to leak at the body and spout location
Most likey the "O" rings on the spout body are bad, need replacing.
Aug 10, 2014 | Grohe 32924000 Tenso Single-Handle...
Need to replace rubber on Grohe Ladylux Plus Pull out spray handle. How to get spray handle apart.
I bought DANCO "universal faucet pull-out spray hose - fits all facuet brands" from Lowe's, which came with all kind of adapter and the hose quality seems to be better than overpriced Grohe spray hose replacement (Grohe part # 46092). The only problem is that you may have to prepare a large rubber washer in order to the handspray (Grohe part#46298) as I don't see this large washer in the package but it is very important to fit in place to prevent water leakage. - Michael
Jan 13, 2012 | Plumbing
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
I am trying to fix a leaky danza single handle bathroom faucet. I cannot figure out how to remove any part of the faucet from the top to be able to change the washer.
There is a allen set screw on the handle it may have a cap over it locate it and unloosen screw and remove handle then un screw bonnet nut then replacement kits available at most hardware,home improvement,or plumbing stores take note of how the parts are removed so to reinstall the way they came out.
Jun 05, 2011 | Danze D203112 Melrose Single Handle...
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
One of the handles on my Kohler faucet does not turn (at all). The model is very similar to the Kohler Memoirs centerset faucet I've noticed that the other bathroom faucet (dual sinks) is beginning to be...
Removing the faucet stems and coating them( inside and out) with plumber's silicone lubricant should solve the problem. If the stem is too corroded, you may need to replace the stem.
Sep 08, 2010 | Kohler Memoirs Centerset Lavatory Faucet...
How do I replace the spring and rubber seal
First turn water off to faucet and remove the screw that hold's the handle in place. They may have a cap on the handle to remove to access the screw.
After screw is out the handle should come off you may have to wiggle it a little to get it to come loose. Next you will have access to the spring and washer for that stem.
It should be located on the bottom of the stem just remove it and replace new ones back in place.
Some have sping's and seat in the body of the faucet if not located on the bottom of the stem.
Jul 13, 2010 | Delta Faucet 2530CBLHP/H25 Innovations 4''...
How do you remove the handle son a Grohe two-handle classic style faucet
May 20, 2010 | Grohe Classic Kitchen/Bar Faucet ...
Jul 04, 2009 | Plumbing
Replace cartridge
The tool you see in the instructions is probably a faucet stem wrench. An adjustable (thumb) wrench could be used to remove the retainer.
Mar 26, 2009 | Grohe Chiara Neu Lavatory Centerset ...
Plumbing Logo
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
