Question about Toro Lawn Mower With Toro Power Tools
Toro model 20371 won't start
It was running great. I didn't use it for about two months and when I took it out, it wouldn't start. I has gasoline in it ans the spark plug seems to be connected
  • 86 Answers
SOURCE: Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
Posted on May 16, 2009
wadembly
  • 462 Answers
SOURCE: toro mower-shut off, won't re-start
check the coil by pulling the plug and lay it against the head put the plug wire on pull the handle if it sparks then its not the coil another thing you can try is spay carb clean or starting fluid in carb see if it starts if that starts it then the float in the carb is stuck if i can help further e-mail me @wadembly@aol.com
Posted on Jun 08, 2009
SOURCE: toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
Posted on Jun 30, 2009
  • 17 Answers
SOURCE: Toro Lawn mower running rough/usually won't start/backfires
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
IN your problem it might also be for some reasons like the crankshaft is bent, that damages the motor internally and cannot be fixed, hppens on older mowers. and is caused by when you run over twigs and branches andything hard!
Posted on Aug 11, 2009
SOURCE: electric starter not working on Toro
I've had the same problem (I think) - the starter will not activate. First time, I found the fuse that's attached to the battery "tray" had corroded. For that I put a good coating of silicone dielectric grease on the fuse contacts and holder. This keeps moisture out. With that it was good for a few months. Now it's gone bad again. This time the fuse is good, but the battery is dead, and so dead that it won't recharge. Apparently the cause of the discharge was/is grass and moisture finding its' way into the battery area, and providing a conductive path between the battery terminals. I was recharging it regularly, following the owners manuals' instructions, so it's definitely not a negligence problem caused by me.
So, obviously what we have is a design flaw in the mower that allows grass clippings to get into the battery area. Time for a recall, but for a quick fix for your current pioblem, you might just find the fuse is corroded, and a replacement + non-conductive grease may be all you need to git'er going.
Posted on Nov 05, 2009
How to remove and replace a rear wheel on toro lawn mower model #20371?
Look and see how the other side is attached and duplicate
Sep 02, 2014 | Toro Garden
Toro 6.75 mower has a recessed plug impossible to remove with socket or wrench. Model 20371 but I know there are other models of Toro with this design.
if your wanting to chang oil the shops tilt it on there side and drain threw filler pipe they dont mess with the plug
Jul 30, 2013 | Toro Garden
2009 190cc Briggs starts but won't run
Ensure the oil is full. It has an oil low sensor. 30w oil.
Jun 13, 2013 | Toro Garden
I have a new model 20371 tor self propelled mower. Used it once. Won't start
Change the plug.
Check coil / wire.
Clean or replace air filter.
Check fuel tank for debri / grass or dirt.
If there is grass or debri in the gas tank, you need to go through the carbruetor because the jets are possibly clogged......
Hope this works...
Apr 21, 2013 | Toro Lawn Mower With Toro Power Tools
Have two string trimmers, both hard to start. shindawa homelite 62061 & toro TB21EC. H/L does great job when it starts. Toro won't come up to speed. Have cleaned carbs in both and checked plug
When you say it will not rev up to full speed, that sounds to me like a blockage either in the spak arrester in the muffler outlet, or the exhaust port is blocked, or the muffler itself is blocked.
May 11, 2012 | Toro Garden
Had rear brakes replaced about a month and half, had a thunking noise. took back, said i had tar on tire causing noise. said it would go away, after 3 to 4 weeks got worst, only heard noise when applying...
Hello and welcome to FixYa!
Even if you are missing a lug nut it won't make a noise if the rest are tight. I suspect that the problem will be on the wheel bearing. The wheel bearing can be worn out that's why you hear a noise. I suggest that you go for the wheel bearing replacement to resolve the issue.
Hope this helps and thank you for using FixYa! Have a good one!
Sep 03, 2011 | Dodge Caravan Cars & Trucks
I have a 1996 Chevy Blazer 6 cylinder 4.3 Vortex engine. The check engine light has been on for a few weeks but it was running just fine. Until all of a sudden it wouldn't start last night. I had...
My first thought would be: If you repaired an emissions hose, take the car back to Auto Zone (or another parts supplier) and let them tell you what code comes up now. You eliminated one problem, now you have to find another.
I wouldn't do a fuel pump without more information.
Gary
Jul 20, 2011 | 1998 Chevrolet Blazer
I have a 2006 Pontiac GT G6 Coup. When we first bought it back in Nov. 2010, it was fine. After a month or two, the clock would reset almost everytime the car was started, radio stations would NOT get...
sounds like a problem with the ignition barrel.the wiring is loose or the connectors are loose or the barrel is faulty,unless thse are all run from the onboard computer.
May 31, 2011 | 2006 Pontiac G6
Toro Lawn Mower With Toro Power Tools Logo
1,678 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
