Question about Samsung Digimax L60 Digital Camera
LENZ STUCK IN
LENZ WILL NOT COME OUT WHEN BUTTON IS PRESSED
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Feb 27, 2013
Power button stuck on acer aspire one netbook
try to open the panel if u r xperienced go to any repairing service center the will do it
Jun 22, 2013 | Acer Aspire One Netbook
Lenz are still
You should take it to the photo shop to ask for repair service, I guess it works! Impact from shock(fall) can misplace the components in the camera and it can't resolve by only turning on and off the camera.
Apr 24, 2013 | Fuji Film FinePix JX500 14 Megapixel...
I have a Dell Demension 5100, and the power button got stuck. By stuck, I mean that the power button is pushed in, but not released. It's stuck as if you pressed the power button, but did not release...
if your PC have restart button then open your PC and check the power cable slots and change them into a reset mode removing reset cable to reset slots and attach to power slot. Then you can power your pC with reset button. If you can open front case then you can outside the button .
Sep 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
My L3 button is stuck pressed down
double check your console where the controllers go, make sure all the pins are there and not bent, if one is bent you can carefully try and correct it with a pair of needle nose pliers, make sure the console is turned off.
Sep 25, 2009 | Sony PlayStation 2 (PS2) Console
Samsung S760 Digital Camera - Not turning on and lenz stuck out.
Yes you are correct lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work
Hope this helps .
If your problem still continues you need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Jan 30, 2009 | Samsung S760 Digital Camera
Lenz stuck out
If the lens mechanism has been damaged or is sticking from foreign material around the lens housing it will shut down when you try to power on. Once in a while you can try to assist the lens by placing gentle pressure against it when you power on and the lens may retract. This will most likely not fix the problem but it may give you a better idea if the mechanism is damaged or not.
Sep 20, 2008 | Kodak Easyshare M753 Digital Camera
Lenz
Ok. Make sure that your camera lens is straight and not slanted. If it is then pull it out with pliers. Once you've done that, then take out your battery. The lens should still be out, but when you turn it on, the whole thing will restart and it will ask you the date and stuff. That's what happened to mine. It is now perfectly fine. I hope I helped.
Sep 16, 2008 | Kodak Easyshare M753 Digital Camera
My CD-RW/VD-ROM is not reading cd or dvd
on my DVD-rom,
it says 0 free space and 0 used space when i pressed properties
help me???
Aug 17, 2008 | Teac DW 28E CD-RW/DVD-ROM Burner
Samsung Digimax L60 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
