Question about Verizon Communications PN-300 Cellular Phone
Factory reset for PN-300 - Verizon Communications PN-300 Cellular Phone
Tip
Cyberhome CH dvd-300
Power supply problems. There are many reports on this site for problems related to the cyberhome dvd player, one of them mine. Here is what I found. The dvd drive was ok it was the power supply that failed after a power surge. The power supply is a flyback power supply using the viper22 switcher by STM Microelectronics. you can download the specs with a schematic diagram simular to the one in the cyberhome unit. I wound up replacing the shunt regulator (TL431) Optical coupler (PS2561-a-1) , the 2200uf cap and the 1000 uf cap. this brought the 5 volt output to 5 volts which was the problem. The parts can be ordered from Mouser Electronics.
1000uf @ 10 volts PN UHE1A102MPD
2200uf @ 25 volts PN UFW1E222MHD
TL431 PN 512-431CLP
PS2561 PN 551-PS2561-1-A
Warning: The high voltage side of this power supply has 120 VAC and 161 volts dc when energized. thak precautions when measuring the voltages on the output. Good luck
on Oct 07, 2010 | Cyberhome CH-DVD 300 DVD Player
How do i unlock or reset for a txt8045vw with out the code?
Go in2 settings & then select factory settings & go with that!!!
Jun 29, 2014 | Pantech VZW PN 215 Cellular Phone
Reset ImageFormula scanfront 300 to factory settings
Below you have link for manual in page 79 you can read how to reset to default values.
Manual
Nov 29, 2013 | Canon imageFORMULA ScanFront 300 4574B002
I want to reset my nextar gps passscode.
You simply need to locate the little reset button and press that for a few seconds, this will reset the unit back to factory fresh. Your user manual is below.
http://www.nextar.com/frontend/proddetail.asp?pn=X3-03&co=10000312
http://www.manualowl.com/p/Nextar/X3-03/Manual/28073
Jul 05, 2011 | Nextar X3-03 Car GPS Receiver
How do I get an owner's manual? I tried on your website, but didn't get the right manual. I need pn - 300.
Use this link: http://www.cellphones.ca/cell-phones/pantech-pn-300/
On the right side of the page, you can download the manual. Hope that helps! Please rate my solution!
- Frankie
May 06, 2011 | Pantech Cell Phones
Dir-300 dlink router asking to reset to factory after installatio
there's an easy way to reset your router back to its factory setting... inspect the physical appearance of your router... there should be s small hole.... inside that small hole is a reset button
How to reset? ..... while the router is on...Using a small pointing object, much better if you use a paper clip..... insert the paper clip to the hole... press and hold the reset button for 10 seconds...
That's it your router will restart itself and the settings is back to its factory settings...
Hope that help you..
Much appreciated if you rate this help... thanks
May 22, 2010 | D-Link DIR-300 Wireless Router
Be-300
The password is an easy thing to get rid of. The problem is, a full factory restore is required. First do a hard reset and then restore the BE300 to factory defaults. The password will be reset.
Hard Reset: Press and hold the Power Button. At the same time, press the rest button on the left side of the device with the stylus (pen). You will see a blue scroll saying Initializing. Press and hold the OK button. Once the Initializing is done, the BE300 will go into the Safe Mode screen. Press OK and follow the instructions to the Restore Screen. From here, you can perform a Factory Restore but you need the original CD or a download of the Factory Restore BIN file.
For full BE-300 support, go to www.be300.org It's dedicated to the BE300 and everything you will need is there.
May 19, 2008 | Casio Cassiopeia BE-300 Pocket PC
Verizon Communications PN-300 Cellular Phone Logo
55 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
