Question about Gateway Computers & Internet
Can't find bluetooth on my gateway md7335u - Gateway Computers & Internet
How do you locate cable strap for gateway md7335u
The cable strap goes in the Kensignton lock slot
see this page of the manual
Gateway 1412 Reference Manual Back
Oct 04, 2014 | Computers & Internet
Tiene bluetooth la gateway 6307
You will find out if you try the following. To turn the Bluetooth radio on: 1 Enable the Bluetooth radio by sliding the wireless network switch to the ON position. If the Bluetooth radio does not turn on automatically, press FN + F6.
Jun 18, 2014 | Gateway M6307 Notebook
Como activo el bluetooth de la gateway 6307
Juan Manuel,
I have to apologize that I can only post this in English. I was able to understand your question though.
You want to know how to turn on the Bluetooth Features of your Gateway 6307.
Try the instructions below:
1. Enable Bluetooth on the mobile phone or other Bluetooth enabled device. This procedure is dependent on the make and model of the phone or the device. You need to see the user manual accompanying your mobile phone or device to see how to enable Bluetooth.
2. Turn on your Gateway laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3. Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4. Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry 5. Select the Local Services tab. Startup type for all services should be set to "Auto."
6. Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
I hope this helps.
Hi,i'm using wireless sharedphone that uses a sim
yes, they are called GSM gateways, they can use your SIM card for your GSM provider to connect any analog telephone, or device...
http://www.gsmsave.com/
there are also bluetooth gateways, that you can use for any bluetooth cell phone (GSM, CDMA, iDEN, etc...) and connect to an analog telephone, or other device...
Mar 21, 2012 | Lands Phones
What's yourGateway MC7321u internal bluetooth installation
You can download the bluetooth and device drivers for your model Gatewaylaptop from this WEB site. Make sure you select your model laptop and thecorrect Windows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Mar 02, 2012 | Gateway MC7321u Notebook
How to activate bluetooth
How to Use the Bluetooth in the Gateway Laptop
ou may have bought a new Bluetooth-capable device like a Bluetooth mobile phone, and may want to load some ringtones or media files that you have stored on your Gateway laptop. This might be the first time you are ever attempting to communicate with a Bluetooth device using your laptop. Normally, Bluetooth has to be enabled on both the devices attempting to communicate. It is no good if Bluetooth is enabled on only one of the devices. All attempts at communicating via Bluetooth will fail. However, if Bluetooth is enabled on both the devices, bringing the two in close proximity is enough for the devices to detect each other. While this is what should happen and it happens most of the time, sometimes the devices need a helping hand. Here's where you come in.
Instructions
1Enable Bluetooth on the mobile phone. This procedure is dependent on the make and model of the mobile phone. You need to see the user manual accompanying your mobile phone to see how to enable Bluetooth.
2Turn on your Gateway Laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry.
5Select the Local Services tab. Startup type for all services should be set to "Auto."Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
Tips & Warnings
If your laptop does not detect the mobile phone even now, turn off the phone and turn it on again while keeping it close to the laptop.
Jan 07, 2012 | Gateway MD7820U (L-LX.W730X.007) PC...
Is my gateway note book have a bluetooth card?
The Gateway MT3705 does not include a built-in bluetooth adapter. You will need to connect and external adapter to add bluetooth functionality to this system.
Dec 08, 2009 | Gateway MT3705 Notebook
Computers & Internet Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
