Question about BYTECC BT-350 Super Speed USB 3.0 to SATA/IDE Adaptor w/ OTB(One Touch Backup) IDE / EIDE, Serial ATA, Parallel, USB Drive Case
Bytecc superspeed bt-350 not working - BYTECC BT-350 Super Speed USB 3.0 to SATA/IDE Adaptor w/ OTB(One Touch Backup) IDE / EIDE, Serial ATA, Parallel, USB Drive Case
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: i have windows 7 and
you might be installing the driver through the right process
click start right click on computer select properties device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
hope this helps you
Posted on Jul 25, 2011
Does the BT-350 work with Windows 10. I can feel the drive spin up but no drive designation.
Windows 10 Drivers - HP Support Forum - 5207043
h30434.www3.hp.com > Laptop & Notebook > Notebook OS
Aug 17, 2015 - 8 posts
So.....is HP going to provide updated drivers for Windows 10? .... sensor andbluetooth (depending on the BT hardware installed). It is the ... I can get W10 to workin an old nc6400 from 2006, and not on a 350 G1 from 2014.
Bytecc BT-350 Drivers Download - Update Bytecc Software
www.solvusoft.com/en/update/drivers/hard-drive/.../bt-350/sub-models/
Manufacturer: Bytecc. Hardware Type: Hard Drive. Model: BT-350. Compatibility:Windows XP, Vista, 7, 8, 10. Downloads: 35,089,716. Download Size: 3.4 MB.
Dec 15, 2015 | Computers & Internet
How to transfer data from 5.25 floppy disk to MacBook Pro?
You can get a 5.25 floppy disk reader that plugs into USB. It should be able to do the disks assuming they are still good. There are several places that sell them online. You could get something like this that will read 5.25/3.5 disks, sd cards, etc. Bytecc BT 146 Floppy disk drive card reader Floppy USB 2 0 BT 146 Floppy...
Oct 07, 2015 | Computers & Internet
I have windows 7 and the Bytecc bt-144 will not work. the drive is not recognized and when i attempt to update it with the driver from the Bytecc web page the computer say the driver isup to date and will...
hope this helps you
Jul 25, 2011 | BYTECC (BT144) External Floppy Drive
I have a BYTECC BT-PCI-SATA 150 I/O controller card but it does not work with windows 7. Is there a driver available for this model?
I can't seem to find a product with the model number "BT-PCI-SATA" that you provided, on the Bytecc web site. You should shut off and open the computer and read the model info directly from the the I/O card to determine the exact model card you've got.
Once you which card you have, you can download drivers directly from Bytecc. There appears to be very limited support listed for both Vista & Windows 7 OSes however. If nothing else, you'll be able to download the latest version of the driver - that may support Windows 7 - without specifically stating that it does.
If you're trying to install Win 7 to boot from a hard drive connected to this controller, it may work if you supply the expanded driver on USB, floppy, etc. when prompted for a SATA driver. Bytecc only offers an email address for tech support, so you might want to send them a detailed note about the problem at: info@byteccusa.com
Hopefully, this helped - good luck!
Nov 18, 2010 | Pc Ware PC CHIPS: PC-Chip M957G...
I'm new to SATA technology. Need simple cable description help.
To resolve this behavior, follow these steps: Start > Run > type > regedit Locate the UpperFilters value under the following key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK. Locate the LowerFilters value under the same key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK. Quit Registry Editor.NOTE: After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software. If the problem recurs, consult with the software vendor for assistance.
Dec 03, 2009 | BYTECC BT-PESAPA / 2-External SATA,...
Cannot copy files using BYTECC Bt-300
check the jumpers on the old drive and see if its powering on or spining up! some of these usb adapters just dont work on old drives if all else faisl open your system and connect it to your pata bus if you have one! if not then use another computer to extract your data and put it on another storage media e.g. flash drives ext hardddisk memory card or dvd or cd disk!
Aug 29, 2009 | Dell Computers & Internet
BYTECC BT-300
hi dear
Make sure you plug in the power for the drive first, let it boot up for a second, THEN attach the adapter and the USB
oke
Mar 22, 2008 | Computers & Internet
BYTECC BT-350 Super Speed USB 3.0 to SATA/IDE Adaptor w/ OTB(One Touch Backup) IDE / EIDE, Serial ATA, Parallel, USB Drive Case Logo
73 people viewed this question
Top BYTECC Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Raymond Lidington
Level 1 Expert
Tom Chichester
Are you a BYTECC Computer and Internet Expert? Answer questions, earn points and help others
