Question about E-Machines eMachines Monitor E15T4
Emachine T2672 will not recognize monitor
Monitor says no input signal, is this something that can be easily fixed perhaps by me. My husband is unemployed so cheapest fix is appreciated.
  • George Bill
    George Bill May 11, 2010
    There is no way of telling what is wrong with it without all of the relevant info.First, you have made sure cable the is plugged in to both the PC and the monitor. Next is a whole sequence of questions that you will need to know the answers to. Like is it a VGA or DVI, when was the last time it worked, if it worked the type of monitor, LCD, CRT ? the possibility of hooking up another monitor to see if it is the monitor or the PC. And a whole bunch more once we know the answers to those including the age of both.
  • 2,229 Answers
First, check to see if the computer is actually running--look for the lights on the front and listen for the fan (also, put your hand behind the machine to see if you feel air coming out). Once you determine that the computer is actually running, look at the monitor. Is it on? Is there a green or yellow light? If not, be absolutely sure it's plugged in both to the monitor and to the computer and the power source.
If you have a yellow light and the computer is running, it might be the video card. If there is not yellow or green light, the monitor is bad.
Find a friend who has a monitor and borrow it. Plug it into your system and see if it works. If so, the problem is your monitor. If not, then the problem lies in the computer.
Posted on Jan 26, 2009
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Plugged in monitor all it shows is check signal cable
Does the monitor have both analog and digital signal sockets? If so, perhaps all you need to do is choose the other input using the buttons on the monitor?
Aug 08, 2010 | Samsung SyncMaster 216BW Monitor
When I turn on computer, the blue light comes on and the computer makes sounds as if it is starting and the monitor light is yellow. If I turn the monitor off and then back on, the screen says something...
No input usually indicates the machine is having trouble getting a video signal from the monitor. Check and make sure the monitor cable is connected properly. If you have another monitor also test the machine with another monitor.
Feb 26, 2010 | E-Machines eMachines Desktop PC
Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
Feb 08, 2010 | HP vs15 15"LCD Flat Panel Monitor
MY MONITOR IS SHOWING AN INPUT NOT SUPPORTED FLOATING MESSAGE. I JUST HOOKED IT UP TO AN EMACHINES COMPUTER. WHAT IS THE PROBLEM?
Does the monitor work on another computer? does the computer work with another monitor? I the answer is yes to both then here is the most likely solution
you may have the screen resolution and/or the refresh rate set too high on the emachines computer. For Windows XP: Boot the computer and use F8 to get the Safe Mode boot menu. Choose the first Safe Mode and log in,... if you see windows come up then go to display settings and and change the settings to something low like 800x600 and refresh rate of 60hz. Restart the system and you will the display and can make adjustments from there.
If either the monitor does not work on another computer or the computer does not work with another monitor,.. or if you are not able to see windows from in safe mode,.. you may have a more serious problem with the monitor or vid card.
Feb 08, 2010 | Rosewill 19" 12MS DVI R911E LCD Monitor
Input signal out of range
Did you mean "out of range". Try reloading video drivers. If that doesn't work, perhaps screen cannot use that resolution.
Jun 28, 2009 | HP Pavilion F1523 15" LCD Monitor
Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Apr 09, 2009 | E-Machines eMachines T3830 PC Desktop
Side Buttons - Not Responding (wrong input?)
These buttons can stick, when you press the buttons do they click
if not then it is stuck in.
Jan 27, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
E-Machines eMachines Monitor E15T4 Logo
267 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
