Question about Meiko FV 130.2 Dishwasher
Quantity ksp1 error
Keeps filling
Auto fill on ge frig doesn't work fills part way
How long ago did you change your water filter? City water or well? Pressure plays a large role in the quantity of water that comes out.
Aug 26, 2016 | GE Refrigerators
Tip
The washing machine is under filling water?
This problem is due to fault in the Water-level switch in washing machine.
The Water-level switch is the part in the washing machine that senses the filling water in the tub. When the water reaches to its required quantity the Water-level switch sends the command to stop the water supply. But if the Water-level switch is faulty. It will sense the wrong quantity of water in the machine. And makes the water supply stop bit early then required. So washer does not fills with required water .The Water-level switch is located at the bottom of the outer tub in the washing machine. Many a times removing and reconnecting the switch makes it proper. in other cases it needs to be replaced.
These will help. Thanks
on Mar 18, 2010 | Washing Machines
Waiting for ever for manual, so in mean time I've just bought 1992 Yamaha XJ900, what oil is needed plus quantities please?
10W40 semi synthetic is best the quantity is normally shown on the engine cover on Yams. My little yam and my Suzi SV have oil level windows in the right side engine cover. These show marks for low and full. Open the oil filler make sure the bike is upright and fill to the full mark,.start the bike run for a little while and recheck/refill as required. Keep checking over a few days just to make sure.
Most bikes 500cc and over have an oil capacity of approx. 3 to 4 liters.
Sep 02, 2014 | Motorcycles
Bosch gbh5 will keep loosing its hammer
It sounds like the gearbox oil is getting low. The GBH5 uses oil in the gearbox, not a grease - the grease is used for assembly only. The correct type is a PG-150 (fully synthetic gear oil). Unable to find it in small quantities, I now use PAG150 oil for automotive a/c systems, it's available in small bottles. As for quantity, no-one seems to know... I just fill to cover the big bottom gears.
Jan 18, 2014 | Bosch Brute Breaker Hammer 11304
Knowing what's the mpg on a l20b?
The classic method is to keep a log on paper or in a smartphone, of odo reading and fuel fill quantity at each fill stop. Do this for about 10 times, total up fuel used, subtract ending odo from starting odo, and then you have miles/gallons = mpg
Oct 21, 2013 | 1989 Yamaha Fj1200 Sport Touring 37k Runs...
Transmission quantity,primary quantity for 2005 softail deluxe
The transmission of your Softail holds 20-24 ounces of oil. Stand the bike straight up and remove the large plug on the clutch release mechanism cover on the right hand side of the transmission. There's a dipstick on the plug. The oil level should be between the lines. To fill the primary, remove the derby cover and stand the bike straight up. Fill the primary through the derby cover until the oil comes up to the bottom of the clutch outer drum assembly, approximately 36-44 ounces. Both came filled with H-D Syn 3 20W50 synthetic engine oil.
Good Luck
Steve
May 31, 2011 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
How much oil do I add to the fryer. is there a fill line
the oil depends on the food item you intent to fry and the size and quantity. If there is only few items then use oil to just dip them in soaked but if there is more items to be done , then you can have the to be fried food just having the fully dipped level of oil.
Since the oil which is fried once is never used, it is good to use the least quantity that is needed so as not to waste oil.
Hence there is no specific fill line, but your Logic..
Aug 27, 2010 | Oster ODF520 Fry Right Deep Fryer
How much oil to fill in front sunspension on fj 1100 - 1985 model and to use 5 grade ?
I wouldn't use 5 wt oil.I fell it's a bit light. Proberbly 10 or 15 wt depending on your size.
Not sure about the quantity.It's not easy getting specs these days & Iv'e found most qualified bike mechanics (including me) set them by the fork oil level these days. I must admit however I do prefer the quantity as some forks are outside the golden rule- & of course then you a required to keep up to date with what theyare(some showas commonly)
To set them by level, check the distance from the top of the shock to the oil with the fork fully compressed without the spring. Set this to 110mm & you will be fine
Hope this helps
Regards
Andrew
Jul 13, 2010 | 1985 Yamaha FJ 1100
Keeps saying "paper out" when paper tray is full
Reduce the quantity of paper fed to the printer.
Mar 31, 2009 | Dell 922 All-In-One InkJet Printer
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Dishwashers Logo
26 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Trevor Turner
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
