Streaking copies I have a Canon NP2120 which is producing a black horizontal stripe (across page) on all my copies. This seems to have started after I replaced the toner cartridge recently. Do you have any suggestions re cleaning &/or adjustments that may rectify this problem? Thank you for your assistance.
  • 1,326 Answers
Have you changed the drum unit recently or emptied out the waste toner in the drum unit? If not try to empty the waste toner and clean the area that is right under the drum unit... * Note* do not wear any thing white... Toner can make a vey big mess...
Posted on Jan 27, 2009
How do i re align the head on aMX432 cannon
  1. Open the printer driver setup window
  2. Click Custom Settings on the Maintenance tabThe Custom Settings dialog box opens.
  3. Switch head alignment to manual
    Check the Align heads manually check box.
  4. Apply the settings
    Click OK and when the confirmation message appears, click OK.
  5. Click Print Head Alignment on the Maintenance tab
    The Start Print Head Alignment dialog box opens.
  6. Load paper in the machine
    Load three sheets of A4 size or Letter size plain paper into the front tray.
  7. Execute head alignment
    Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  8. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    When you have entered all the necessary values, click OK.
    [img src="http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/MX450%20series/1.0/EN/PPG/images/i_note.gif" alt="" >Note
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
      (B) Most noticeable vertical streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
      (A) Least noticeable horizontal streaks
      (B) Most noticeable horizontal streaks
  9. Confirm the displayed message and click OK
    The second pattern is printed.
  10. Check the printed pattern
  11. Confirm the displayed message and click OK
    The third pattern is printed.
  12. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal stripes.
      (B) Most noticeable horizontal stripes
Jan 05, 2015 | Cannon Office Equipment & Supplies
Black 3e Cartridge
check the printer head and roller inside the printer
also check the nozzle because it may be clogged due to some
dust
Jul 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon NP6221 copier makes copies with black streak down middle.
I suggest You Go to Official Canon Printer Page For You Canon Problem On Below Canon Page URL:
Copy Has Vertical Black Streaks In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
  9. Check the printed pattern
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
  15. Check the printed pattern
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
My Canon PC-25 copier is streaking
Toner cartridge is defective - replace it
Apr 06, 2009 | Office Equipment & Supplies
Brother HL 1440 Laser printer-horizontal black streaks
check your drum may the corona ware is broken . change the drum.
Feb 27, 2009 | Brother HL 1440 Laser Printer
BLACK LINE ACROSS THE COPY CANON IMAGE 2200
Most likely your drum unit is worn out. If it reaches the yield of 50k or more, it starts to develop grooves in the drum and toner gets stuck in the groove and is applied to your pages. If you have a service company, they can change it for you. We sell the drum for $220.
Jun 30, 2008 | Canon imageRUNNER 2200
226 people viewed this question
k24674
jasbo
jasbo
