Question about Linksys 5 x 10/100Base-TX - Ethernet Switch Surge your network with surefire data transfers in full duplex m...
Problems I have satellite internet can i use the 5 port 10/100 switch to hook up two computers?
  • 1 more comment
  • g_ramsey1 Jan 26, 2009
    yes it's going to be hardwired r45 into both computers will this slow the internet connection down if both computers are on at once?
  • g_ramsey1 Jan 27, 2009
    wired wired all the way
  • Frank
    Frank May 11, 2010
    yes, what are you going to use?
    wired or wireless?
    Genius:
  • 1,605 Answers
Satellite connection to WAn port of the router.
the 2 computers can be connceted to any of the 4LAN port.
you can use the router just the way it is.
Posted on Jan 27, 2009
  • 33 Answers
Absolutely. The router will have an uplink port. It will indicate on the back. Hook the modem from sat to the uplink and the other 2 computers to the other ports. make sure the computers are on DHCP (they should be defaulted to it) and they should auto connect
Posted on Jan 26, 2009
  • Ben Wine Jan 26, 2009
    No, It would be hard to slow down normal browsing..... If you were both downloading huge files or streaming video you may see some slowage
How can i hook my toshiba satellite pro to my tv
there are some options here.. however they are limited to what ports are available on your computer AND on your tv.. for instance..
1 s-video, this is a round like ps/2 port thatt he computer and your tv have to have for video.
2 you can use a vga port from the laptop onto the tv for video
3 you can get a switch box that will be VGA from the laptop to VGA on the switch box that will use AV cables to the tv like a dvd player, and you'll just hook your computers headphone jack intot he jack on the converter box for sound through the tv.
4 buy a brand new smart tv.
Aug 05, 2011 | Toshiba Satellite Pro L300 Notebook
I have 10 computers and 2 printers networked in the office. I'd like to hae them all wired. I bought a 10/100 switch but not sure how to hook it up with my router. Any advice?
Most low to mid range switches require no configuration. Switch-to-router connections use a standard straight-through CAT-5 network cable, same as for your PC. Connect any switch port to any LAN port on the router (you didn't say if your router has more than one) and then connect your PCs and printers to the other switch ports with CAT-5 network cables. The WAN port on the router remains connected to the upstream (Internet) provider.
Feb 19, 2011 | Computers & Internet
How do i connect two computers so they both have the same ip address i have a linksys 5-port workgroup switch will that work ? also i had hooked it up but only one of my computers had internet
They cannot have the same IP address due to the mechanics of DHCP. Buying a cheap 50$ router (not switch) will fix your problem as your internet service provider will see that device as a single unit that it will assign an IP and then the router will give out internal ip addresses so that they can get online. The switch does not have this functionality.
Feb 16, 2011 | Linksys EZXS55W EtherFast 10/100 5-Port...
Can I use more than one modem on my phone line to support multiple computers? Also, where can I obtain a list of modems compatible with a Netopia 2249n? Thanks
Hello
The short answer is no you really cant use multiple modems. The internet should come in to your home via the modem, then go in to a ROUTER. Many times the router will have 3 to 5 ports on the back to hook your other computers too. This means running cables. Another way is to use WIRELESS cards that you can find on the net or from best buy.
If your router does not have any extra ports you need to buy something called and ethernet switch. Again they come in 4 and 8 port models up to LOTS AND LOTS Of ports for big companies. You hook the switch in to the router, then hook the computers in to the switch.
I hope this helps you
Nov 27, 2010 | Arris Netopia 2240N-VGx Router
I have my internet through my cable company and i want two com hooked up but are not going to have them online at the same time so can i use the 10/100 5-port model#EZXs55w by using the line coming out of...
Hello Friend
You could definately use Network Switch-10/100 5-port model#EZXs55w to Connect to Network Router or Modem using Uplink Port at back Panel of 10/100 5-port model#EZXs55w Switch.
Simply Connect Modem cable to Uplink Port of Switch and connect computers to other 2 ports of switch. Allow computers to get Automatic ip addresses..if computers still not getting ip addresses auto--contact cable company and config your cable modem to use NAT or enable NAT--
Oct 10, 2009 | Computers & Internet
Linksys 5-port switch
When connecting a switch/router to another switch a specially-wired crossover ethernet cable is necessary, unless both units are designed to automatically determine whether they need to operate in crossover or "uplink" mode. This is more than likely the problem you are encountering.
Jan 29, 2009 | Computers & Internet
Cannot connect 2nd computer
you can always give it a static ip...if you need to know how to do this repost here..
Jan 26, 2009 | Dynex 5 Port 10/100 Ethernet Switch...
I have a cable modem. from the cable modem I go to a 5 port hub
That is because most cabel internet providers only gives you one public IP. Please go to a Best Buy, Office Depot, Staples, Walmart, or Targer, and ask for a LinkSys Router. The router will do NAT (Network Address Translation) that will allow more than one PC share the single public IP. This will solve your problem and will cost an estimated $30.00. The router is simple to hook up, just plug the cabel from your modem into the Internet/WAN port on the router. And the two computers into any of the other ports. Be sure to unplug both cable modem and router then plug up the cable modem first, once the ready light is on, plug up the router.
Adam
Nov 15, 2008 | Stratitec 5-Port 10BaseT Ethernet Hub...
Help
hello!
-- who is ypur internet service provider?
-- what is the operating system of your computer
you may try ff and see if this may help you solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this didnot work try upgrading the firmware of your router
Apr 28, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Dynex ESW5 connecting PC and Mac
after hooking it up only one computer has internet
Apr 13, 2008 | Dynex 5 Port 10/100 Ethernet Switch...
Linksys 5 x 10/100Base-TX - Ethernet Switch Surge your network with surefire data transfers in full duplex m... Logo
215 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
