Question about Whirlpool Washing Machines
Whirlpool ultracare 2 sm8525079 wont spin
Sm8525079 rev a
3 Suggested Answers
gwshaw71
  • 83 Answers
SOURCE: Whirlpool Ultracare Doesnt spin out well
this is a direct drive unit it will spin or make alot of noise. do you have the spin speed set correctlly to what your washing if so look under unit and check motor coupling and look for any signs of transmission oil leaks
Posted on Dec 07, 2007
richroth
  • 9472 Answers
SOURCE: my whirlpool ultimate two will spin and drain but
Take a look at this tip I wrote on the no agitate or spin condition of your washer.
Posted on Oct 18, 2011
Whirlpool top loader sm8525079 rev A will not go into spin mode
No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Oct 05, 2014 | Whirlpool Washing Machines
Whirlpool sm8525079 rev
I will help you provided a serial I need a model number check the tag on the washer not the book. Whirlpool authorized
Feb 11, 2014 | Washing Machines
My Whirlpool model sm8525079 will not spin. It will make a humming noise that I assume is the agitator but no real clue. It will drain though.
this is not a modle #,try raising the lid if a top loader and look low center under lid. if top load you may have a broken drive coupling.pretty easy fix once you get cabinet off.2 phillips up front on older on back on some,all at the very out side edge of control panel,some newer have end caps to remove for front screws.newer have spring clips.use putty knife between washer top and panel out side edge.two spring clips remove pump,two screws and clips remove motor,coupling is next.
Dec 10, 2013 | Washing Machines
Whirlpool sm8525079
check your belt also pulleys and motor
Whirlpool Sm8525079 Rev fills up with water, but won't agitate.
Your lid switch has a fault, Sometimes the switch can bend which means that it won't always operate.
Mar 08, 2012 | Washing Machines
Hoover washing machine wont spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Nov 01, 2009 | Hoover UltraCare HC6 160E Front Load...
A lot noise, when spinning after rinse
Forget the brokenhearted melody........ten years is well past the use by date of most machines. You face a major service or a replacement.
.....I dont get emotional about inanimate objects......or crows for that matter.
Oct 20, 2009 | Washing Machines
Nov 10, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
15 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
