Presarion 1300nx will not boot
Change memory card from 256 to 512 and now computer will not boot,even with old memory,gives off one beep,for about 3 secounds,fans come on,still no boot
    Novelist:
    Champion:
  • 201 Answers
Try removing the CMOS Battery
First check to see if the memory is the correct match.
After sitting the memory sticks remove the COMS battery.(looks like a watch battery) connected to the mother board. Give yourself thirty second and re seat the CMOS Battery than try stating your computer.
Posted on Jan 26, 2009
3 long beeps on bootup,black screen,gateway atxeg lx3 700s po4
This is an indication that there is a memory issue. Reseat the memory in the computer and try again. If this fails and you have two or more sticks of memory, try just one in a slot at a time. Hope fully one chip will fail and you have found your bad memory chip. If all chips fail in one slot, try the other, this would incate a bad slot on the mother board.
Good luck and I hope this helps.
Mar 01, 2012 | Gateway Computers & Internet
Computer boots up and gives beeping noise, and monitor fails to detect computer.
Two components inside your computer is causing thins beeping sound. If the beeping like this, beeeep beeeep beeeep beeeep , then you have a problem with your memory card, clean your memory card and try to boot it again. If this doesent work, replace your memory card. If the beeping sound goes, beeeep beeeep bip bip. Then you have a problem with your video card. Try to clean it first, then reboot. If this has no effect, repace your video card... I hope this would have a positive effect on your computer. Have a nice day my friend.
Aug 20, 2011 | CyberPower C Gamer Xtreme 5212 Desktop -...
Won't post
if your computer wont boot and is not giving the post noise
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Mar 06, 2011 | ASUS P4S800-MX Motherboard
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Laptop will not boot with new ram memory card
Those beeps are code for what is wrong,
go here to see what yours mean:
http://networking.ringofsaturn.com/PC/beep.php
Sep 05, 2009 | HP Pavilion dv6000z Notebook
Added Memory, Now Computer doesn't Boot! HELP!
Either you have defective SDRAM chips, or your CPU was damaged when you installed them .. in either case, your only solution is to have the problem diagnosed by a professional.
May 26, 2009 | Gateway 500 CS PC Desktop
PC can't boot LEDs are all Amber colour and flashing.
the memory sticks are not connected properly as you are getting the beeps out of the computer when turning on...
if in case the memory cards are connected properly the system should not beep while turning it on so please try to reconnect the memory cards properly & see if you are getting the prompt"the amount of system memory has changed" coming up in that case the system is working fine.
May 07, 2009 | Dell Dimension 3000 PC - P4 2.8GHz/256MB...
3 Beep sounds-No boot
As you probably know 3 long beeps on an Intel motherboard is memory failure. Even if RAM is good your Motherboard may have problems in reading your ram module.
If you are using a PCI or AGP video card try also removing and putting back video card, video adapters use shared RAM and can give you troubles with RAM.
Always perform all maintainance on motherboard with power unplugged and avoid to touch contacts and circuits with your finger.
If the 1GB module is new, verify with seller that your motherboard support this memory, some motherboard do not support double density RAM.
Aug 16, 2008 | Intel Desktop Board D845GLVA...
Computer won't boot up
there is problem in your hardware, if you are using a video card which is not on board temporarily uninstall this and use the on board to determine if this is a video card problem. if it does not boot then, try to exchange the location of your ram memory if you are using one or two, this way you can check if this is ram memory problem
Dec 07, 2007 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
