Question about Raymarine Boating
Ray marine st6001 drive stop
I am receiving a "drive stop" message along with an alarm when the autopilot is engaged and the boat looses heading.
  • 3 Answers
SOURCE: radio works on tech bench, not in the boat
Yes, the yellow wire is the switched hot lead - it is typically connected in one way or another to the ignition switch. There is also a smaller gauge red wire that is connected directly to the battery (through a fuse of course). Both of these wires have to have power for the radio to work. Also the black wire has to be connected to a good ground. If all three of these wires are confirmed to be in good order (power where there should be power, ground where there should be ground and no shorts) the radio should at least power up when they are all hooked up and the ignition is on.
Posted on Jun 25, 2009
SOURCE: Simrad AP 11 Autopilot control head
I happen to have an ap11 head unit in good condition, please contact me.
Posted on Nov 08, 2009
SOURCE: Autopilot shows "no rudref"
how do connect my autopilot
Posted on Mar 17, 2010
  • 64 Answers
SOURCE: ST6001 when press auto it
Try reversing the motor leads on the CPU. If this doesn't work you will have to check the rudder feedback to see if it is operating properly. The easiest way to check this is to steer the wheel from port to starboard extremely slowly and make sure the readout on the control head has a smooth transition when you turn the wheel.
Posted on Sep 01, 2010
  • 3 Answers
SOURCE: Problem: Autopilot does not
jimtippettau:
Which drive are you using with the AP24, is it just a hydraulic pump on a powerboat, like our RPU80, or is it a hydraulic linear drive (like our HLD-2000) or draglink drive (like our DD-15) on a sailboat?
Posted on Mar 31, 2011
Raymarine 4000 + autopilot. I immediately get an RG Fail message when I engage the autopilot on my Catalina 320 Sailboat.
I am not familiar with your particular model autopilot, but I do know that Raymarine autopilots can be fussy. All must have a compatible gps feeding it, of course. All must have a rudder angle indicator if your auto pilot connects to the wheel or rudder instead of directly to the tiller.
Aug 25, 2017 | Raymarine Boating
Problem: Autopilot does not engage. This is a new problem as it was working quite recently. Model: Simrad NSE8/AP24 with AC42 Autopilot Computer. Attempts to engage the autopilot result in an...
jimtippettau:
Mar 24, 2011 | Simrad AP24 AUTOPILOT DISPLAY UNIT
ST6001 when press auto it engages but within seconds turns hard to port and stays engaged until we turn off the power at A/P switch.
Aug 23, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Oct 28, 2009 | Simrad Boating
Boat on screen does not point the direction the boat is going e-80 series also chart will not go course up or heading up like the radar does unit is set in relative motion mode
The direction of the boat symbol is depending on the compass course from the autopilot. You will see that your GPS course (COG) and magnetig heading on the autopilot differs. Solution is to calibrate autopilot compass. Will advice you to not use course up, stick to north up or heading up.
Sep 08, 2009 | Raymarine C80 GPS Receiver
The rudder sensor works like a light dimmer, so you get 5V and ground on the outside two connections and a varying voltage between about 1 and 4 volts depending on rudder position
847-746-0100 www.technicalmarine.com
Jul 07, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Raymarine ST6002 Smartpilot Alarm Message ''Seatalk Fail 2''
Very possible that the Wind instrument has a defective Seatalk interface - it happened to me. You could try your Wind in another boat, just connecting it temporarily to the Seatalk Bus - if it jams those it is the problem
Your autopilot should have a separate Course Computer such as the 100, 400, S1... somewhere. Some models have two SeaTalk busses, and the recommended installation is to use one bus for the 6002 control head alone, and the other bus for instruments etc, so a SeaTalk fail on the instrument bus will not disable he Autopilot. I retired my boat this way (after the dealer took the one-bus shortcut).
The real solution is to have the Wind instrument fixed. The cheapest work-around is to cut the yellow SeaTalk wire between the 6002 and the Wind, so that the Wind instrument gets power but does not affect the data bus. That should let the AP and Wind each work normally and independently (no Wind-angle mode on the AP).
Raymarine have a forum you should join for more info and help.
Sep 05, 2017 | Raymarine Boating
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Apr 06, 2009 | Raymarine E120 Multifunction GPS Receiver
Auto pilot
difficult is it to install Raymarine 8002 autopilot in 270 Sea Ray
Jan 14, 2009 | Raymarine St8002 Smartpilot Autopilot...
The S1G display occasionally shows no data. The autopilot works fine for hours then fluxgate seems to hang up.
Try to borrow a computer unit to detect if the fault is in the computer unit or the display unit
Mar 19, 2007 | Raymarine ST6001 S1G Hydraulic GPS...
Boating Logo
73 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
