Question about Peg Perego Vespa Scooter
Et2 Cutting out and not maintaining revs
My x reg ET2 is playing up.  i recently filled it up with too much oil and since then i'm having trouble.  It doesn't have enough revs to keep going and stalls at the lights every time i stop.  How do i increase the revs on the bike?
It has to keep going for the next 5 months before i move away...
    Problem Solver:
  • 7 Answers
There is an adjustment screw on the carburetor facing towards the back wheel. You have to reach down about finger length. With the engine running and the ET2 on its stand, turn the screw until the engine revs up to a level you r happy with.
Happy scooting
Posted on Jan 27, 2009
I have a et2 vespa put 98 ron fuel in the tank ran for about 3 kms now does not run anymore
You are a bit vague with your question.
Did it stop suddenly? Does it crank over?
Was there oil in the self mix tank?
Is there a spark at the plug?
Did you drain the carb for water?
Piaggio / Vespa scooters run on 98 petrol no problem.
Aug 04, 2014 | Vespa ET2 50 Motorcycles
I have an et2 vespa i put a bit of 98 ron fuelin the tank it ran for about 3 kms then konked out now it wont even start
the Vespa ET2 50 has a two-stroke engine which needs an oil mixture in the gasoline. There are 2 (two) tanks under the seat: 1 is for gasoline and the other for 2T-oil.
If you dont't fill that oil tank the engine will run dry after a couple of miles and the bearings in the motor blow up.
Then you need a complete rebuild of the engine which costs a lot.
http://www.wotmeworry.org.uk/manuals/ET2/et2manualpt1sm.pdf
Need a power cord for a Salton hotray model ET2
I'm selling an ET2 with power cord:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300841414208
Dec 31, 2012 | Sport & Outdoor - Others
How to fix a wing mirror on Vespa ET2
you need to pull up the rubber cover at the base of the mirror and tighten the nut at the right position... fix-wing-mirror-vespa-et2-wrvo0vnsxenp22qrsalmbzkb-3-0.jpg
Sep 25, 2012 | Vespa ET2 50 Motorcycles
Need a carburator kit for a 2003 vespa ET2
Ideal that you approach the Vespa spares dealership.please log on to :http://www.vespaspares.co.uk/
Nov 30, 2011 | Vespa ET2 50 Motorcycles
Vespa et2 Engine
there might be a workshop manual for it here
Free Piaggio and Vespa Motorcycle Service Manuals for download
or i have some here
vespa
Jul 06, 2017 | 1999 Volkswagen Passat
Piaggio Vespa ET2 Scooter slows down when eccelerating
-such strange behaviour occurs when the rollers in the variator case are worn, they have to be replaced by a dealer piaggio-vespa-et2-scooter-slows-down#solution-section-wq3avpzkaaw4sd2xavwlekgs-5-0.jpg piaggio-vespa-et2-scooter-slows-down#solution-section-wq3avpzkaaw4sd2xavwlekgs-5-2.jpg
piaggio-vespa-et2-scooter-slows-down#solution-section-wq3avpzkaaw4sd2xavwlekgs-4-3.jpg
piaggio-vespa-et2-scooter-slows-down#solution-section-wq3avpzkaaw4sd2xavwlekgs-4-4.jpg
Dec 10, 2009 | Peg Perego Vespa Scooter
Vespa et2 clock
there is only 1 fuse on an et2 and if the horn, starter and indicators work, then this iis not the problem.
It is most likely the battery which is at the back of the speedo. to get to this you need to remove the mirrors and screws from the handlebars, split the casing, disconnect the speedo cable and all electric blocks (carefully) and turn the speedo over. there is a little round plug that needs to be removed and the battery is behind it.
I think it is a rechargable battery, so replacing it with a normal battery will only work temporarily.
Mar 04, 2009 | Peg Perego Vespa Scooter
Peg Perego Vespa Scooter Logo
357 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
