Question about Sony KDL-42EX440 - 42" LED-backlit LCD TV
Does my SONY KDL-42EX440 support arc
Does it support arc
Sony bravia kdl-60w600b and trying 2 hook up my sony theatre system ht-m7/ht-m5/ 4 some reason it reckenise the amp but the audio system is active but there is no sound coming out of it plz help me?
Hi
please connect your system through HDMI cable & select HDMI port which is ARC written on led then after connecting press sync on batten & select options for your system this is one step if sound comes through your hi fi then ok otherwise go to av setup & select audio out put sound must come
Jun 16, 2015 | Sony Televison & Video
Why is the picture so dark and how do I make it brighter?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 05, 2014 | Sony KDL-42EX440 - 42" LED-backlit LCD TV
My Sony KDL-42EX440 will not turn on
Have you tried to do a "reset" ALL modern electronic items often get "locked up" and unplugging them from the wall will often get them going again. Unplug for at LEAST 30 seconds--then try again. If this does not help--the SMPS board may have failed on you. A good repair shop may be able to repair the board instead of replace it.
May 06, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
I need a user manual for Sony Bravia KDL-26V4000
Hello Mr.Daniel,
Here's the User Guide in pdf [35685kb] for your Sony Bravia KDL-26V4000
User Guide 2 in pdf[6330kb].
Hope this helps.Thanks!
Please vote this answer if helpful.
Dec 18, 2011 | Sony Televison & Video
I need a users manual for 32" sony television
The model you want iformation is is discontinued. However you can find the manual at for a small fee. Hope this helps.
sony kdl-26s5500 kdl-37s5500 tv service manual download
Sep 08, 2011 | Sony Televison & Video
Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
May 06, 2010 | Sony Bravia KDL-46VL130 TV
Do not have user manual and need to run setup
Click Sony Support to download user manual of KDL-32XBR6
Manual has detailed info about initial setup.
Mar 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TV Problems!
This is usually the high voltage on the inverter, balancer or backlight arcing to the chassis or at the connections. One quick fix was to look for a burn spot under the inverter(s). If that's the case, insulate the chassis at the point of the spot with a few layers of electrical tape 600v dialectric strength or better and carefully clip the leads just above the solder joint on the inverter board to widen the arc gap. If the white pink wire connectors arc too long they will charr requiring replacement. Cost varies depending on the problem.
Jul 19, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KDL-42EX440 - 42" LED-backlit LCD TV Logo
125 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
