Question about Panasonic MCCL481 Bagless Vacuum Cleaner FOR 220 VOLTS
HOW TO CLEAN THE FILTER MCCL481 - Panasonic MCCL481 Bagless Vacuum Cleaner FOR 220 VOLTS
Honeywell 50150 stopped filtering the air
If you are recycling the filters then they could be totally plugged up.
Mar 03, 2014 | Honeywell Air Purifiers
I own a HAP424G Air Purifier, and I need to know how to clean it. It has a large, flimsy filter, as well as 2 HEPA/Carbone filters. They've accumulated quite a lot of dust and I need to clean them, but I'm...
If the "flimsy filter you are talking about is a plastic or rubber foam you can clean with mild soap and warm water. Allow it to dry thoroughly before re-installing it. The HEPA filters are disposable items not meant to be cleaned. They are designed to be replaced and they sell filters on their website. In a pinch you could knock or tap in on a counter to knock out the loose debris and then using compressed air "like those sold in a can" can blow off more debris before reusing the filter. This is a temp fix and will reduce the efficiency of the filter and is not recommended unless you simply cannot get another filter.
Nov 06, 2013 | Air Purifiers
Can I wash panasonic vacuum cleaner mc-cl 481 filter?
Just do what I said in the clarification, I missed my "post solution" button!
Aug 25, 2012 | Panasonic MCCL481 Bagless Vacuum Cleaner...
Can the hepa filter be cleaned?
The link below will show a page on how to clean and care for your air purifier. Although the Hepa filter can be cleaned multiple times, the manufacturer recommends you replace it every 12-18 months.
Bionaire Air Purifier Care + Cleaning
Jan 09, 2012 | Bionaire LC1460-U Air Purifier
I just bought the purepro 200. I ran it for about 7 hours in a normal house setting and it turned off and the cleaning light came on.I have unplugged it and tried it again. This time it went off in 10...
John, when the clean filter light came on, did you clean the filter? Or just unplugged it and tried again?
In 7 hours, the unit probably picked up a lot of dust, that's why the clean filter light came on. Try cleaning the filter( if you haven't already) and that may solve your problem. When you reinstall the filter, be sure that it is seated properly, so the the safety trigger switch is activated.
Hope this helped you to solve the problem.
Mar 23, 2011 | Montgomery Ward Pure Pro Air Purifier
I have cleaned the filters, and i still get the Clean Filter message. It is running fine, but the red letters Clean Filter are still there... any suggestions???
How did you clean the filters? I run mine through the dishwasher by themselves and it works pretty good. The tops and bottoms of the filters near the edges need to be wiped pretty clean.
Jan 02, 2011 | Brookstone Pure-Ion (506840) Air Purifier
My sister gave me her Brookstone Pure ion Air purifier....The "clean filter" light flashes red....I wiped the filter with a damp cloth...so think it is clean...?....Is this how to clean it? ....and how do...
Wiping it off won't clean the filter. I submerse mine in hot soapy water ( oxiclean w/any favorite multipurpose liquid cleaner.Let it air dry completely before placing it back in unit.I have tried the dishwasher method and it didn't clean it.I also thoroughly wash all crevices of the unit.If red light doesn't go off, reclean the filter(s). It has all ways worked for me.
Sep 23, 2010 | Brookstone Pure-Ion UV Air Purifier
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
Cleaning the filter
Yes to get the clean filter light to go off, you have to clean filter, put back in the machine, and hold down the power button for 3 secs to reset it. the clean filter light will go off!
Nov 14, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Manual for Oure Ion Advanced
the clean filter light will reset itself once the filter is completely clean. Try dust off the areas where the filter is inserted into as well.
Oct 30, 2007 | Brookstone Pure-Ion UV Air Purifier
Panasonic MCCL481 Bagless Vacuum Cleaner FOR 220 VOLTS Logo
18 people viewed this question
Top Panasonic Air Purifiers Experts
Are you a Panasonic Air Purifier Expert? Answer questions, earn points and help others
