Question about Honeywell Programmable Thermostat Heater
Honeywell t8112d cycle time - Honeywell Programmable Thermostat Heater
Honeywell manuals
I usually google the model number when I'm on a service call and need the installation instructions for programming some thermostats. I googled "Honeywell T8112D" and the pdf file was the first link, that's the one you want. Hope this helps!
Dec 07, 2013 | Honeywell Programmable Thermostat Heater
Why does fan not cycle off on heat cycle for TH5220D1029 thermostat
1) normally you must to exchange by new batteries with the same types alkalines FULL charges.
1a) see if there are some wires loose and tight it
2) reset and program it again , follow the instr. manual if you do not have download from Honeywell from section support give the number, model and do it.go to http://yourhome.honeywell.com/home/
God bless you
Oct 08, 2012 | Honeywell Th5220d1029 Non-programmable...
I have a Honeywell Focus pro Series 5000 Model Th5320U. How often should this thermostat cycle in an hour?
Hi, That depends....some on how you have it set up and some on how the building is responding to the unit....bottom line, I cannot give a definitive answer...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Aug 05, 2011 | Honeywell Heating & Cooling
I have an intermatic C8865 timer. i want to wire it into an EFM model AF150-1 coal stoker furnace, because the fire goes down to far inbetween actual times heat is called for. also have main switch for...
Intermatic C8865 timer is a 5-hour cycle timer that repeats same cycle each 5 hour period.
This timer has 120Volt clock motor and is 120V timer.
Timer has NO and NC terminals.
NO terminal turns ON when timer turns ON
NC terminals is ON all the time, except when timer turns ON. At this point NC terminal turns OFF.
You have 3 things: 120V timer, 120V honeywell transformer, 120V stoker motor/fan
The transformer needs to be ON at all times.
The stoker motor is going to turn ON when the cycle timer turns ON.
You have 120V cable with black wire, white wire (and bare ground, which connects to green ground screw and to other bare grounds and won't be discussed further)
Black wire is hot
White wire is neutral
Black wire connects to 'Switch common terminal' on timer.
Same wire also connects to black wire on Honeywell transformer.
White wire connects to 'Clock terminal' on timer
Same wire connects to white wire on Honeywell transformer and to white wire on Stoker motor.
So all the white wires are connected together.
Last wire is black wire to stoker motor.
This wire connects to NO terminals on timer.
Here is drawing.
Add a comment any time
Dec 13, 2010 | Intermatic C8865 Timer, 1HR CYCLE TIME, 30...
We have a digital Honeywell Thermostat and it's not that old but we have the heat setting at 68 degrees and the inside temp is reading 71 and our fan doesn't seem to turn off.
Hi, Most all of the Honeywell t-stats have a temperature adjustment feature...also check the the cycle rate is the right one for your heating system... You will find all of this info in the manual for your t-stat...
heatman101
Dec 08, 2010 | Honeywell Heating & Cooling
AC unit goes on and off every 3 minutes
It should not be doing that. The thermostat is pre-programed for only 4 cooling cycles per hour. You can change the program by :
�� To access the configuration menu, press both up/down buttons
simultaneously for 3 seconds.
�� To go to the next parameter (menu item), briefly press both
buttons simultaneously.
�� To modify a parameter, press one of the buttons.
�� Repeat steps 2 and 3 if necessary.
�� Press both buttons simultaneously for 3 seconds to exit
the configuration menu.
You are looking fpr parameter CPH this number tells the unit how many time per hour to come on lower it to leghten the time betwen cycles.
Jul 12, 2010 | Honeywell Electronic Programmable...
I have a honeywell ct3200 with a trane xl 80 furnace. it will cycle on to the right temp, go off and cycle the furnace back on 30 seconds later. Is that normal? It is 32 degrees outside, set at 68
Hi, check page 22 in your manual, it says "Adjust the screws on the back of the thermostat as instructed on page 7." Your furnace is a 80% efficiency but is also a high efficiency 2 stage heating system so try adjusting screws A and B both ways and see which gives you the correct cycling.
Your manual is here:
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0653.pdf
Jan 18, 2010 | Honeywell Programmable Thermostat Heater
3 year old Lennox system stops intermittently 2-3times past 24hrs
i would have the thermostat receiving 24 volts all the time by running the c terminal from the air handler to the thermostat and go from there
Jun 21, 2009 | Honeywell Heating & Cooling
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
