Magicard enduro error code 11
Can't find panel please check film and printer mechanism.
  • juancca Apr 17, 2009
    I changed the film for a holographic film, now the printer show me a message "check film". I have review all, but the eror is the same. Please, does somebody know to solve this problem?
2 Suggested Answers
  • 7 Answers
SOURCE: enduro magicard printer all that comes up when
vcbvvcbvbvc
Posted on Feb 17, 2010
Error code 24:06 magicard
Hi There,
General Error 24:06 may indicate a problem with the front card sensor (very rare though). Open the lid, remove the dye film. Check that there are no cards jammed near the front of the printer (just before the flipper unit).
Try unplugging the printer. Cancel all print jobs if any are pending.
Plug in the printer. Once initialised, open the lid, run through the cleaning sequence (a Magicard cleaning kit - 3633-0053 is required). If the problem persists even after cleaning, contact your Magicard dealer. The warranty status can be checked here;
http://www.magicardonline.net
Enter the serial number of your printer in the QuickSearch box (Menu -> Info -> Serial Number)
Hope this helps,
MC.
Apr 14, 2014 | Magicard Rio Card Printer
How to reset magicard enduro duo printer
hello
I have a big problem
my magiccard printer both sides
give my the back said (black photo )
How I can fix that please
Feb 02, 2014 | Magicard Printhead Enduro & Enduro Duo...
I GOT COLOR RIBBON BUT THE PRONTO SED TO ME THAT A HAVE TO CHANDE BUT THE RIBBON IS NOT DONE YAT!!
Hello fabiogb_765,
Did you notice an error number when your printer tells you that it is out of dye film?
The error number is important.
Regards,
MC.
Jan 11, 2013 | Magicard Enduro/pronto Ymcko Color Ribbon-...
Card jam please clear printer
Hi Imran,
I realise you probably resolved this issue a long time ago, but this may help others with the same problem (Card Jam on Rio Pro / Enduro / Enduro+).
Immediately after the Card Jam - Please clear printer mechanism, there should be an error number. All card jam errors begin with 06:??. Most common would be Card Jam 06:05.
This error means that the rear card sensor has detected a card.
However, the card has not past through the sensor. This could indicate a failed card sensor (always on). This may sometimes be caused by static on the cards.
To confirm this, switch to 'Hand Feed Mode' (on the front panel: Menu -> Hand Feed Mode -> ON). Cards are then fed (when requested) from the hand-feed slot on the front of the printer. If the error changes from Card Jam 06:05, to General Error 24:08, this would suggest a faulty rear card sensor (very rare).
Try leaving the printer switched off, and with the DC power disconnected for a few hours. If the problem persists, you should contact Magicard Technical Support.
With Best Regards,
MC.
Apr 09, 2012 | Magicard Rio Card Printer
Card jam please clear printer mechanism 06:05
Card jam 06:05 error;
This indicates a problem with the rear card sensor.
Contact your Magicard dealer.
Error code 24:03 magicard- card was stuck in machine
Hi There,
General Error 24:03;
This error is caused by a faulty RFID tag in the colour dye film.
Contact your Magicard dealer for a replacement dye film.
Sep 06, 2011 | Magicard Rio Card Printer
Magicard alto
Hi There,
Sorry to hear you are having a problem with your Alto printer.
A common fault is where the dye fil cassette runs out, the user is warned, but they keep clicking on 'OK' rather than opening the lid and checking the film.
To resolve this, first of all, upgrade your printer's firmware to the latest version (V4.06).
You can download this by following the link below;
Enter your printer's serial number in the QuickSearch box at the top right of the page.
You will then be offered the latest firmware version to download.
Secondy, there is a small 'O' ring drive belt for the dye film advance motor. This is behind the right-hand side panel. This belt may have either come off the pulleys, or it can sometimes double back on itself and get trapped. In either case you may need to replace it to be on the safe side.
The Magicard part number is RIO/0037/R
If you contact your local Magicard service centre they will normally stick one in the post free of charge.
I hope this information is useful to you.
With Best Regards,
MC.
Oct 17, 2008 | Magicard Alto Card Printer
The cards are sticking
Hi There,
Im_useless:
0.126 is not a Magicard error number. On a Rio 2 printer, the error number will be displayed on the LCD display. It should look like 02:?? or 04:??, etc.
Are the cards feeding out of the hopper?
How far into the printer have they gone before you get the error?
Are any of the dye film panels printed before the card gets stuck?
Are the cards ejected when you click on 'OK'?
Guest:
The most common reason for the dye film sticking to the cards are if they already have overcoat printed on them (you can not print over overcoat). Also, if you are printing very dense images, try selecting 'ColorSure' mode in the printing preferences, Try reducing the YMC printhead power in printing preferences.
Nov 30, 2007 | Magicard Rio ID 2 Card Printer
I have error whenever i just select encoding only
Hi There, I presume (from the error number) that you are using LC3 (monochrome) dye film in your printer. This error is normally given when the printer detects LC3 (monochrome) dye film, but is then sent 'Colour' printing data from the driver. If you have 'encode only' selected there should be no printing data sent to the printer at all (number of copies = 0), only the mag stripe information should be sent. I suggest you contact Magicard Technical Support in the UK (I am one of their support engineers). We will need some further information (serial number of the printer, etc). Please also check you have the latest firmware (print the internal test card by pushing the button on the back) and are using the latest driver. All are available for download from: www.magicard.com To contact customer support send an email to: customer_service@ultra.co.uk Advice is free regardless of whether the printer is in warranty or not. With Best Regards, Alan.
Aug 20, 2007 | Magicard Avalon Card Printer
258 people viewed this question
jasbo
jasbo
