Question about Newport Brass Plumbing
I have an older Newport Brass kitchen faucet leaking all over the place. Model # NP941. Where can I buy replacement iin Los ANgeles area?
  • 374 Answers
SOURCE: How to remove old Mueller (1951) wall mount faucet
Faucets are installed from behind the wall and there fore you will need to either cut the sheetrock on the opposing side or cut part of the tile out on the front to gain access to the valve. It is better if you come in from behind as you can build an access panel if you ever need to gain access again.
Thanks for using Fix Ya.
Posted on Nov 09, 2008
  • 297 Answers
SOURCE: I have purchased a Tuscany Brass kitchen faucet
if i remember correct this connection is plastic to plastic,if this connection is broken you must replace the hose and the head.i hope this helps.good luck with you project.
Posted on Jul 31, 2009
meBNme
  • 334 Answers
SOURCE: Kitchen Faucet Leak
The stem and washers inside the faucet need to be replaced.
If you Do it yourself the parts typically will cost you less than 20 bucks.
Most plumbers will charge 75 to 100 for this relatively simple Job.
You can order parts directly from the manufacturer, or from a local plumbing supply house.
The faucet may still be under warranty and the parts would be free. Here is ther number for Price pfister.
1-800-PFAUCET (1-800-732-8238)
Posted on Aug 24, 2009
Testimonial: "As you suggested, the faucet was under warranty and Price Pfister is sending me some parts at no costs. Hopefully, the parts will resolve the issue."
  • 3600 Answers
SOURCE: I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Posted on Aug 30, 2009
  • 127 Answers
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Posted on Oct 18, 2009
Were can i take my rowenta steamer for repair in the 90035 los angeles area
Anaheim, Berkley, Fresno, Bakersfield, Los Angeles,
Long Beach, Sacramento, San Diego, San Jose and San Francisco.
Google Rowenta repair Center, choose a city and go!
Jul 24, 2014 | Rowenta Commercial Garment Steamer - White
I have an older model 841 bath wide base fixture that has stiffened up to a point it takes a man to open and close it. It looks very much like the current 800 fixture except it has a porcelan base. i...
Below find the diagram for your faucet....
The handles are held on by a set screw either under a cap in the center of the handle, or on the side with an allen head screw
one the handle is off, you unscrew the eustecheon cap and can get into the cartridges that most likely needs cleaned or replace.
You can contact Newport brass for parts and info below...
Contact InformationNewport Brass is committed to providing the highest level of customer satisfaction. We look forward to assisting you. Please contact us using the information below.
US Customer Care Center
Aug 23, 2011 | Newport Brass Plumbing
945 Kitchen Bridge Faucet - Swivel Spout, 9-1/2" (no Han) Brand: Newport Brass NB945-26 Series: 900 The stem moves up and down slightly when I turn on/off the water pressure. It does not leak but...
There is a good chance that if you remove the handle there will be a retainer of some sort. The retainer's job is to keep the stem/cartridge from pushing out due to water pressure. It may be in the form of a nut or a clip. Be careful removing the handle because if the retainer is completely disengaged then the stem/cartridge may shoot up. Turn the hot and cold water off at the valves located under the sink and relieve the pressure by turning the faucet on. If it's a loose nut it will spin freely. Tighten it. If it is a clip you may need to play with the stem/cartridge to align it properly before the clip will move into place..
Jul 15, 2011 | Newport Brass Plumbing
Dear Sirs, When lifting the handle assembly to use the faucet on model 7100 that has been on the sink for the past thirteen years, the water is leaking from that assembly kit. So the question that I am...
13 years , I would recommend replacing it. You basically got its lifetime out of it.Think re-model, I like to replace mine every 10 years or so.It's time to change the decor. It's actually easier and less frustrating than replacing the diffusor assembly. They are not easy to get off after 13 years & corrosion in inevitable.Your faucet could easily crack or break. You'll actually save time and can avoid a headache doing so.
May 31, 2011 | Plumbing
Leaky eurostream kitchen faucet
if its leaking under the handle, all you need to do is remove the blue and red cap on the handle under you will find a 1/8 allen screw, loosen screw and remove handle and tighten the brass nut a little which will seat the packing underneath.
Jun 19, 2010 | Plumbing
Where can i get my mixer repaired in los angeles area ?
1220 North Las Palmas Avenue, Los Angeles - (800) 644-0858
2818 Sunset Place, los angeles - (310) 600-6007
911 Wilshire Blvd, Los Angeles - (310) 399-8484
I have never used any of these places so I can't recommend them or tell you anything about them. I got them thru Google.com
Apr 06, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Moen single lever kitchen faucet leaking at base and through spray. Can it be fixed? I lost my installation manual. Are there any online?
base leak is from bad o ring or loose spout very easy fix you can get a washer kit at lowes all you need is a allen wrench(sometimes comes in kit) a pair of channel lock pliers
May 09, 2009 | Moen 7840 Camerist Single-Handle Kitchen...
Newport brass kitchen pulldown loose
is the wait on the line to draw it back and did u check under the sink to make sure ur not hung up on anything?
Dec 31, 2008 | Plumbing
Plumbing Logo
20 people viewed this question
Top Newport Brass Plumbing Experts
Donni Steen
Tom Chichester
Are you a Newport Brass Plumbing Expert? Answer questions, earn points and help others
