How to reset ip address for a belkin router
SOURCE: IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
SOURCE: factory settings for a Linksys RV042
connect your router your computer via LAN cable
click start on windows
click run and type CMD
On the DOS command prompt type IPCONFIG/ALL
look for the gateway address, that is the IP Adress of your router
SOURCE: belkin router f5d8230-4 ip address change
Call 661-588-4401 and he will take your money and Ipod and you will never see either again!
There address is 12316 Stonington Street Bakersfield, CA 93312 and they will tell you to send a money order for $89.00 and to make it out to Gloria Anderson or John Medeiros or Richard McNeill. BEWARE!!!!
SOURCE: Opening the NAT connection for Xbox 360 working through 2 routers
Hope this helps!
