Question about Plumbing
Replace cartridge for Pegasus faucet
How do to get handle off to relace the cartridge on model # ASMEA 112.18.1
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
  • 297 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Posted on Jul 15, 2009
smokenic
  • 49 Answers
SOURCE: How to remove a pegasus faucet handle, brushed
with most fausets there will be a cover hiding the setscrew holding it in place. it'll be right on top and need to be pry'd up. or the piece you'd use to turn the handle with, will unscrew.
Posted on Sep 20, 2009
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
SOURCE: handle won't stay up
I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
Posted on Jul 22, 2010
Looking for a cold cartridge for 2 handle lav faucet.
We don't have any plumbing parts here! Check eBay, Alibaba, and Amazon, or consult your local hardware store.
May 12, 2015 | Plumbing
Pegasus tub and shower thermostatic faucet handle stripped
Sep 24, 2012 | Pegasus Technologies Plumbing
My Pegasus kitchen faucet leaks at the top, even when off. I'm not sure which model, it has one handle with a side spray. What do I do.
Turn off water supply to sink. Wrap top of goose neck with rag and use a pipe wrench to remove ( lefty loosey, righty tighty). Inspect interior of faucet for worn o - ring or gasket and take damaged part to local hardware store for replacement parts. The gasket or o - ring may be on the gooseneck ( the part the water comes out of between the handles or below a single handle faucet).
Good luck!!
Nov 29, 2010 | Pegasus Technologies Plumbing
How to remove the cartridge from my pegasus shower/bath faucet. the instructions are not very good.
remove handle , unthread collar , same with chrome body base . make sure water is turned off from valve
Oct 18, 2009 | Union Pegasus F1228100PBV Series 5000...
How to remove a pegasus faucet handle, brushed nickel, dual handles
Sep 15, 2009 | Pegasus Technologies Widespread Lavatory...
No water pressure on Pegasus kitchen single handle faucet
Those new faucets generally have a lower water pressure due to legislation passed in 2007 that reduced that maximum allowable gpm (gallons per minute). I hate to tell anyone this but there is little if anything you can do. First of all, make sure the shut-off valves are open completely. I know that sounds elementary but I've seen it a bunch of times.
Also check to see if the aerator is blocked with a bit of debris.....unlikely if the flow is uniform but still an easy fix.
Hope I didn't break your spirit too much....
Apr 28, 2009 | Pegasus Technologies Pegasus F1225100BN...
Single handle pegasus kitchen faucet. No water pressure when turn
Kitchen faucet? Remove the internal parts and check for blockages.
Apr 05, 2009 | Pegasus Technologies Pegasus F1225100BN...
Pegasus faucet problem
The part you need can be purchased at Home depot
Jan 07, 2009 | Pegasus Technologies Widespread Lavatory...
Plumbing Logo
323 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
