I need to know how to open the top of my glass top stove to replace a bad burner. Can't figure out how to lift it up or figure out how to get in there to put a new burner. Kenmore glass top stove
SOURCE: I have a GLEF379DQA glass to stove and I want to
1) Unplug unit 2) Remove back plate covering controls on back of oven 3) Notice 2 brackets, 1 on each end holding 2 screws-remove the screws 4) On front remove 3 screws underneath front ledge directly above where oven door closes 5) lift top up about an inch, and pull forward towards front of oven 6) You can now lift it to service - beware wires are still connected - dont pull too far forward and up
SOURCE: stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
SOURCE: Maytag Electric Ceramic Glass top stove
You can replace the failed component which is either the burner or the switch that controls the burner. A voltage test would have to be done to determine which compoonent has failed. Generaally it is worthwhile to repair the range.
one burner does not work. How do I replace it? It is a magic chief
I have a triple burner, but the middle portion does not work any longer. I have a Maytag Gemini.
I have the same issue with my Frigidaire, one of the burners is not longer working
I got the same issue, a burner in my Frigidaire is not longer working
