Question about Weslo Cadence Ds23 Treadmill Power Supply Board For Model Number:
Motor controller mc-60 - Weslo Cadence Ds23 Treadmill Power Supply Board For Model Number:
Can I wire a Kenwood MC-60 mic to a Galaxy 2517
You can. You'll need to figure out the function of the MC 60 wiring and also that of the stock 2517 mic to rewire the MC 60 to it.
jeverge2@gmail.com if you need help with that, I'll see what I can find for you
Aug 24, 2014 | Radio Communications
Cassette tape size
Will mc-60 cassette tapes fit WHAT Sony?
Jan 01, 2014 | Audio Players & Recorders
My proform 750 CS will power up and incline but the motor won't start moving. While performing troubleshooting on the MC-60 SCR Motor Controller the D11 LED is the only LED lit up on that circuit
please LUBE the deck belt+rollers bearing. see the video attached.
If the problem persist TIME to replace the old deck belt board.
This happen because the lack of maintenance schedule in LUBE.
God bless you
note:forget it the LEDS troubleshooting, you must see the functions ONLY when there are electronic problem with the electronic board+sensor2_4_2013_6_01_12_pm.gif
Feb 04, 2013 | Exercise & Fitness
I need a motor speed controller model MC-60
Go to the next company and you need to buy:
www.fitnessrepairparts.com
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 26, 2011 | Exercise & Fitness
I hav e Model # HRTL7183 The speed control buttons do not work so it will not run I am told the contol board is no longer available
the control board is still available for this i am sure of it. you may have to get a used one. look at ebay. this is an icon treadmill i am sure. probably has a mc-60 or somethin like that. i have a few spares. look on the treadmill and it should say on the control board what type of board it is. it is located in the motor area the computer board should say what model it is. go to treadmill doctor. com
Jan 27, 2011 | HEALTHRIDER R65 Treadmill
I have a problem with my MC-2000ES motor control board. The HV BUSS LED is not on and therefore no DC voltage to run the motor.I have checked the diodes and SCR circuit and all look OK. I believe there is...
just change the Diodes D4015L and SCR´s S4015L whit a caugting buy the new change and ready or is a MC-2100 w / transformer just change the MOSFET IRF250N
Aug 31, 2010 | Proform Crosswalk 500 Treadmill
My Nordic Track Exp 1000 X runs in reverse.
Your treadmill runs on a permanent magnet DC motor. If it is running backwards someone has swapped the pos and neg leads where it connects to the motor control board MC-60. OR
the brushes were removed from the motor, and installed into the WRONG locations. there is a plus sign and a neg sign on the end cap of the motor, make sure the RED wire is going to the pos sign,.and so forth.
to get to the motor you'll need to remove the 4 phillips head screws FROM the bottom of the motor enclosure: lay the unit on it's side to get to them. 2 in the front,.and 1 on each side. If it doesn't come off easy,.you've missed a screw.
Lay the unit back down, and start digging in.
Lastly, you can verify the MC-60 is outputting the wrong polarity voltage with a voltmeter. Disconnec the motor and connect your voltmeter on a 20 volt DC range ( at least). plug your unit in, and turn it on at 3 mph. you should see positive voltage applied to the read lead.
It's very unlikely that the control board would swap the polarity, so, my bet is,...the wires are switched.
good luck.
Jan 26, 2010 | Nordic Track NordicTrack Treadmill, A2550
I need a Motor Speed Controller Model MC-60
Well I find a controller on ebay.com
You can purchase it from below link -
http://cgi.ebay.com/Repair-Rebuild-MC-60-Treadmill-Motor-Controller-MC60_W0QQitemZ140347773158QQcmdZViewItemQQptZExercise_Fitness_Cardio?hash=item20ad6110e6
Just copy and past the above link to your web browser and follow the site instructions to purchase it....
Good Luck!!
THanks
Oct 01, 2009 | Proform 730 Folding Treadmill Model...
I get error code c-0046 and now machine will not work. What do I do?
C0046: Fusing Cooling Fan Motor /1’s failure to turn
Relevant Electrical Parts
Suction Fan Motor (M12) Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the connector of motor for proper connection
and correct as necessary.
Check the fan for possible overload and correct as
necessary.
M12 operation check PWB-MC PJ18MC-9 (LOCK)
PWB-MC PJ18MC-7 (REM)
6-P
4 Change PWB-MC — —
Fusing Cooling Fan Motor/1 (M9) DC Power Supply (PU1)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
necessary.
3 M9 operation check PU1 PJ17PU1-5 (LOCK) 2-K
4 Change PU-1 —
Jun 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
ERROR CODE C0096 - BIZHUB C350
2.6.19 C0096: Image Transfer Belt pressure/retraction failure
2.6.20 C0098: Fusing Pressure Roller pressure/retraction failure
1st Image Transfer Retraction Position Sensor (PC12)
1st Image Transfer Pressure/Retraction Motor (M11)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the M11 connector for proper connection
2 PC12 I/O check PWB-MC PJ3MC-6B (ON) 6-B
M11 operation check PWB-MC PJ5MC-1~4
(Pulse Output)
6-C
4 Change PWB-MC
Feb 18, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Weslo Cadence Ds23 Treadmill Power Supply Board For Model Number: Logo
42 people viewed this question
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
