Question about Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop
Monitor has ac power but screen is blackout
Speaker is working but screen is blackout
    Scholar:
  • 58 Answers
Computer black screen of death is usually related to hardware or driver. It is typically caused by software errors in device drivers: in Windows systems by poorly written device drive , It also be caused by physical hardware faults, such as faulty RAM memory or power supplies, overheating of components, or hardware which is run beyond its specification limits . On the other hand, registry damage,corrupted program and viruses are the major causes of computer black screen,too. According to the issue you've got, the following tips may be available to you.1.An efficiency troubleshooting step on hardware is to start your computer with the minimum hardware necessary to run the operating system. If your computer starts successfully it proves that one of the removed hardware devices was the cause of the STOP message. Otherwise move to the next solution.
2.Boot your computer in Safe Mode by pressing F8 at startup. Then go to My Computer and right-click on Disk C to select Properties from the dropdown menu. From the Tools tab, perform an error check and disk cleaning. 3.If the about two solutions doesn't work, the last one I can suggest to you is to create a bootable disk. It is the most quick and effective way for you to solve the problem. You just need to download a software can be used to burn your CD/usb into a bootable one and then boot your computer from it. Run the software to fix the issue after that. There are few free software for you to use, so if you want to take this solution money is indispensable. Windows Boot Genius owns a better cost/performance among such kinds of software I've used. It may be a good choice for you if you have money to pay.
By the way,reinstall your operating system can also help you out if nothing important stores in it.
source:http://www.reset-password.net/black-screen-of-death-and-blue-screen-of-death.html
Posted on Jan 21, 2013
My LG monitor blacks out intermittently when warm, I have tried it on another computer so it is a fault with the monitor. It blacks out every few seconds, sometimes it takes longer. It is 2 years old.
after blackout, check the screen as that. look in to the monitor in side angel,
and if you can see darken live image in that and its working. in that condition, your
LCD panel is working and the problem is no light.
in that case you need to repleace or repair the " inverter unit " in that monitor.
that unit makes the high voltage for back light.
after blackout , you cant see any darken image like as that, and or totally power
goes off , that is different problem. for solve that need advance trouble shooting
and can be need advance repair.
Jan 03, 2011 | LG Flatron W2243SPF Widescreen LCD Monitor
My samsung 2233 has been totally blackout. Using a light, I can read the word behind the black screen. To solve the issue, I re-install all drivers, monitor adaptors, anti-virus softwares, finally formated...
Hi:
Unfortunately, it isn't a Windows problem, but a monitor power or backlight failure. Your monitor's high voltage inverter board, or the backlight has failed. Often it is too expensive to repair, and cheaper to replace the monitor if it is out of warranty
Dec 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
My fathr gave me a hp f1703 monitor. As soon as i plug it in the whole screen flashes on and off. The light on the power cord also flashes, but if i unplug the monitor and leave the speakers plugged in the...
try another monitor i re placed my cord and the graphics card and it didn't do me any good i replaced the monitor last and it works fine now. and my speakers pluged into the monitor the monitor i bought didn't have the port for speakers so now i need to get usb speakers so check it out. hope this helps
Oct 17, 2009 | HP Pavilion F1703 17" LCD Monitor
Screen black out
best way to trouble shoot a monitor is to plug into a different monitor do you have a desktop monitor you can try?also alot of laptops have a small button that turns monitor off when you shut it down around the base of the monitor make sure it isnt stuck.is it going into hibernation? try pulling the battery and unplugging it then plugging it back in.if it is stuck in hibernation that should work.
Apr 23, 2009 | HP Pavilion DV6500Z Notebook
Monitor Blackout
Here is a website that provides instructions to repair the inverter on a similar model:
http://josepino.com/?howto-repair-dell
Feb 23, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Blackouts
have you checked your ram
Apr 03, 2008 | Neovo E-19A 19" LCD Monitor
Lcd monitor problem
use the economical approach replace the ac power supply if this doesnt work replace your monitor with a new one.
Because its probably the same amount of cost to fix it as it is to get a new monitor.
Jan 01, 2008 | HP Pavilion F1703 17" LCD Monitor
Blackout
Try lowering your brightness setting below 55.Its hard to see at just the right angle.The monitor has a failsafe installed for over voltage use of the bulbs for the screen. The lights go out but your screen is still there.
Aug 11, 2007 | HP L1902 19" LCD Monitor
Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
