Question about Garden
Echo cs302 chain oiler not working - Garden
  • 7 Answers
After you have cleared all the obvious stuff aka; bar hole, oil outlet, etc, look inside the oil tank to find the oil pipe and screen, if they are intact and not clogged the "O" rings on the adjuster are bad. If not clean the little screen and replace the oil pickup tube, yes they are still avalible. It's a bit tricky but can be done through the oil fill cap hole.
Posted on Jun 03, 2014
  • 3 Answers
SOURCE: Makita DCS51018 Chain Saw Oiler
Before you tear apart and purchase a new oiling assembly. Remove the sprocket cover, bar, and chain. Above the bar studs there is a horizontal groove the oil should flow from. If it is packed with sawdust clean this out. After cleaning or it is clean start the saw with all of the items removed. You should see the oil flowing. If there is no oil the oil pump is bad or clogged. If it flows your bar is clogged. Clean the oiling hole on the bar and groove. Hope this helps.
Posted on Feb 27, 2009
  • 205 Answers
SOURCE: chain oiler
Saw dust has clogged the passage way in the bar. take the bar and chain off and clean the groove where the chain runs, also near where the bar mounts to the saw there are holes in the groove that intersect with cross holes in the center of the bar, push a paperclip through top and bottom.
If this works for you please leave a rating, thanks
Posted on Mar 25, 2009
  • 226 Answers
SOURCE: Can't get the chain oiler to work. Using standard bar oil.
You can always put some penentrating oil in the saw oil tube by the bar, spray it in with the plastic straw attatched. Sometimes this will clean things out. As far as the tube being un attatched,,,, taking case apart is usually the remedy - kinda takes a while... :) Hope this helps you, Rick.
Posted on Apr 26, 2009
steve_lima
  • 181 Answers
SOURCE: chain oiler 357xp
when you say that you changed the gear,was that the plastic one?check the other gear that is on the pump itself.make sure that it isn't worn.then make sure it spins freely.if it doesn't that will be you problem.cleaning them has never worked for me.........just replace it and the plastic gear.with both being new you should have no problems with oiling.the little pump gear gets scored up inside and they stop spinnig fast enough to work properly.hope this helps let me know if you have any questions
Posted on Jun 01, 2009
SOURCE: Trouble with Poulan 2150 Chain saw automatic chain oiler
Thanks, guys. Right, I do fill it partially now, but it's annoying. Oh well, there is no simple way to restrict the line - I have disassembled the unit and one would only hope the designers would think about a simple device for adjusting oil flow, but there is none. Primitive, since oil will flow at very different rates in cold and warm weather...
Posted on Aug 16, 2009
Show way to turn oiler for chain
the right is less oil
and the Left is more oil
to be sure ask a dealer a good one give you a response
if it not give you a response ask a another dealer !
Aug 27, 2014 | Echo Model Cs 315 Cs315 Cs-315 Chain Saw...
Chain slipping
Resistance through the guide bar may be too much for the clutch assembly to cope with. Trust you have plenty of chain oil running through the chain and guide bar. If not, resistance will increase creating heat and eventually smoke, ultimately permanent damage to the parts. Ensure the oiler is working.
Jul 14, 2014 | Echo Garden
ECHO 452VL NOT OILING CHAIN
Sounds like you have a blocked oil pump. With the flow regulator fully open and no cage filter on the end of the oil intake hose its probably pulled through dirt and blocked the pump.
Jul 27, 2013 | Echo 452vl 452 guide plates
Echo cs 3450 oiler does pump oil to chain bar, leaks along side case
not familiar with that model but check that the oil passage from the pump to the bar is clear and not broken or cracked
Feb 19, 2013 | Garden
How does the oiler work on a echo cs440 chainsaw
hello, depends on the model you have, mine has a gear drive,and others are gravity flow,there is a inside tube with a filter that drains to the out side for oil,hope this helps.
Feb 22, 2012 | Echo Garden
Echo CS-302 chain saw with no instructions (Inherited)
the echo cs302 is equiped with an automatic oiler that lubricates when the engine is running the manual states the unit runs on a 20:1 mixture 89 octane fuel with 6.4 oz of tcw3 oil per gallon
Apr 10, 2009 | Echo Garden
Garden Logo
473 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
