Possible there are errors within the panel or there is flow issues. You can check the inlet flow, remove inlet valve and check, if not clean and reset. Also check on the drain filter, remove and clean.
If the fault stays, it can be due to moisture in the panel or a memory issue on the processor. remove panel , heat using a dryer, reconnect all harness tightly and try.
SOURCE: kenmore front load tumble action washer
Snaggs, If your model number begins with 417 it could be a couple of issues. Start with the drain pump. Remove the bottom panel and see if the pump is clogged with coins or debris. It will be on the right. Check the pump impeller. Have a bunch of towells handy as you will have a lot of water coming out at you. When you drop the bottom panel you will be able to see if the belt is on in back. If this does not clear up the problem, more than likley it will be in the motor control board. Catriver...post back.
SOURCE: Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
SOURCE: Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
