Question about Fishing
Interceptor float tip
If you use interceptor floats and find them hard to see at a distance try drilling the top the diameter to take the width of a float and insert the top of an ordinary float into it with a bit of superglue it only needs to stand out from it about 22mm because if you make it too long t will tip over sideways. You will find it will stand out and you will be able to see it at a distance.Make sure you pick a suitable colour that you can see.
  • 117 Answers
SOURCE: Whirlpool dishwasher float 'assembly' model-DU810SWPQ2
Enter your model number into a site like partselect.com to get a parts diagram for your dishwasher so that you can see what the part looks like. The float just extends through the base to close a micro switch so the dishwasher shuts off the inlet water valve.
http://tclaundryrepair.com/
Posted on Feb 20, 2009
  • 4 Answers
SOURCE: cylinder 4 misfire on a 2000 crown victoria interceptor
first cylinder 4 is the last on the passenger side . first pull the coil out and check if there is water where the plug is. if there is take the water out and dry up the coil. if you find water you got a crack manifold or a bad intake manifold gasket. if there is no water replace the coil. good luck
Posted on Apr 28, 2009
mechanicm639
  • 253 Answers
SOURCE: turn off 05 equinox daytime headlights
You can turn them off with the headlight switch, rotate it counter clockwise. You will have to do this every time you start the vehicle. Thank our government for this one. There is also a relay in the under hood fuse block DRL relay. Pull it, but be sure your low beam head lights still work with the switch. Good Luck
Posted on May 05, 2009
  • 6 Answers
SOURCE: Black and Decker KD950K drill - how to insert drill bit
most keyless chucks have a button on top that you push in near the chuck it locks so you can tighten or undo
Posted on May 27, 2009
  • 66 Answers
SOURCE: 99 crown vic police interceptor steering wheel??
i have ran into 2 issues in these vehicles---if it binds while sitting still also, check the steering shaft, i have found the u-joints in the shaft tighten up and binds dangerously tight---if they are free, sounds like you may have a steering box issue or restriction in a line---hope this was helpful!!
Posted on Jul 07, 2009
I am currently doing a carburetor rebuild on my yamaha and I am trying to adjust the float height, but I am having trouble finding the clearance
this is a rule of thumb for carbies where the float is pivoted from the top cover
with the float in position turn the top upside down and the float will now be in the position it is in when controlling the fuel
the float top should now be close to parallel to the top cover it is attached to
if you manage to get a measurement for that distance it is measured by the specified measurement as a twist drill and it is to move under the float as you roll it along the top cover
not to move it up or miss it but just touch it
adjustment is by bending the small tang that is connected to the needle
now if such a measurement is not available simply ask your service dealer what it is
May 13, 2016 | Yamaha Virago Xv 535 Xv535 Engine Cover...
Tip
on May 13, 2014 | Fishing
Tip
Float valve overflowing on a motorcycle
My Yamaha wr250 was leaking fuel out of the overflow badly. I cleaned the seat, changed the valved, adjusted the level. Nothing worked. In the end, it turned out the seat was damaged due to age. Yamaha did not sell a new seat for it, you have to buy a new carburetor. Here is a tip that is easy to do to resolve it provided you have already replaced the float valve, adjusted the float level, and cleaned the carb.
Items needed:
a small tube of lapping (valvegrinding) compound(Available at your local auto store)
1 can carburetor cleaning fluid.
About 5 Q-tips (If your float valve seat hole is bigger than a normal Qtip, you can purchase oversize ones at any drug store)
High speed drill
remove the carburetor, bottom bowl, float, and valve.
Put one Q-tip at a time in the drill
Apply a dab of lapping compound to the end of the tip(about twice the size of a b.b.
Stick it in the float valve seat and letter rip for about 10 seconds. The Q-tip will take on the shape of the float seat and lightly polish the seat smooth again. You might want to do this a couple of times the first time to ensure it takes.
Once you are satisfied that all scars are removed, take a can of carburetor fluid and spray out the seat. Ensure that all the lapping compound has been removed.
Put the carb back on. Try out the bike and see if you can get it to leak. If it does, repeat the process. I had to do it about 5 times to get mine to completely stop.
Final Note. This tip is provided for people that have already replaced the float valve, adjusted the float level, and cleaned the carb. If you cannot purchase another seat for your carburetor, without buying a new carb. this beats that hands down, but I strongly suggest you do the first three steps first. Anything goes wrong, your not out anything anyway.
Ride hard, or stay home.
on Aug 28, 2010 | Motorcycles
How do I adjust the float?
normally there is an adjustment but you will need a workshop manual to find what that adjustment is
if it was ok before repairs then it will be ok after repairs
however the check is to turn the top of the carby upside down and there is a measurement between the float and the top of the carby
it is usually measured by the width of a twist drill moving between the float and the lid
adjustment is by bending the tab of the float that the needle touches
a quick check is that if the float is parallel to the lid then it will be close
Oct 31, 2015 | 2010 kawasaki KLX 110
How do i adjust the float on an autoline 2 barrel c8114a carb?
if the float is attached to the top of the bowl (cover) the invert the cover and measure the distance from the cover to under the float. There will be a dimension and it is measured by the use of a twist drill that is that dimension. Bending the tab on the back of the float will be the adjustment.. Some have a plug in the side of the bowl that you remove and adjust the needle and seat height until the fuel is at the threads of the hole.
May 23, 2014 | Cars & Trucks
INFO ON HOW TO DO A CHAIN ADJUSTMENT ON A 1999 HONDA VFR INTERCEPTER
Your rear wheel is mounted on an offset cam. Part #6http://www.bikebandit.com/houseofmotorcycles/2004-honda-vfr800-interceptor-interceptor-abs/o/m2792#sch303670 Loosen the bolt on the back of the wheel/cam/bearing holder at the back of the swing arm.Part #16 http://www.bikebandit.com/houseofmotorcycles/2004-honda-vfr800-interceptor-interceptor-abs/o/m2792#sch303667 Use tools Part # 15 and 7or 6 (whichever fits the circumference of the cam) together to rotate the bearing cam until the chain has approximately 1 and 1/2 inches of slack from the top to the bottom of its movement in the middle of the chain slack. Then retighten the bolt on the back of the swing arm. Happy Riding
Jul 10, 2011 | Honda VFR 800 Motorcycles
2008 crown/vic police,feul guage reads empty,have jumped at tank harness black/orange to yellow/white still reads empty
either a fuse on the fuse block is faulty (not likley if other gages are working),,,,,of the gage itself needs replacing....also the sendind unit at the tanks might be bad bad and not responding to the jumpering.
Feb 26, 2010 | 2008 Ford Crown Victoria
Looking for a 1974 Jensen Interceptor owner & Repair Manual
I have a copy of a 1969 Interceptor Mk1Workshop Manual which I downloaded for my car. send email if you want help alfabeta@fsmail.net
Mar 14, 2009 | 2006 Triumph Tr 7
Anyone can give me the driver of Joystick Wing Man Interceptor ?
http://drivers.softpedia.com/get/JOYSTICK-GAMEPAD-WHEELS-and-TABLETS/LOGITECH/WingMan-Interceptor.shtml
Jan 13, 2009 | Logitech WingMan Interceptor (963152-0403)...
Fishing Logo
140 people viewed this question
Top Fishing Experts
ray gallant
Steve P
Steve P
Andrew Taylor
Andrew Taylor
Are you a Fishing Expert? Answer questions, earn points and help others
