Question about Braun Flex Integral 6550 Electric Shaver
Repl batt 6550
Want batteries replaced only.
2 Suggested Answers
SOURCE: Model 6550 electrc shaver how i can open case
I.fix problem
thanks
Posted on Oct 03, 2009
I need to replace the batteries, but I do not know what part number to purchase. The batteries do not have any part number on them. Braun 6550 shaver
You will find the correct battery type at shaveroutlet.com. See link below. You will need two batteries.
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
I suggest that you read the installation tip on the item page as well.
Also, does the green charging indicator light still illuminate when you plug the shaver in to charge? If it no longer lights, don't waste your time with the batteries because your have waited too long to change them and the circuit board is now damaged. Unfortunately, circuit boards for model 6550 are no longer available from Braun
Oct 09, 2010 | Braun Flex Integral 6550 Electric Shaver
I want to replace the braun 6550 with the same shaver, but i cant find anyone who sells them so what is the replacement shaver
shaveroutlet.com may have a PCB that could work in your 6550 model but from what I discovered it is not the same as the one you currently have. It will make the razor function but the LCD will not be available to show battery life. you will have a red and a green light only. If you can live with this than I would suggest contacting shaveroutlet.com. I have the same problem as I have a model 6550 and I have been looking for a replacement PCB ..Printed Circuit Board but have been unable to find one. Call Brian at shaveroutlet.com. I plan on contacting him next week ...Feb 7, 2013 with same problem
Nov 02, 2009 | Braun Flex Integral 6550 Electric Shaver
Filter beeping and repl batt
the owners manual shoul assist you on how to reset the filter timer however the filter reminder will not cause the unit not to work . the batterys going bad will. change the batterys and if you dont have the manual and cant reset the filter reminder just ignor it or replace the stat
Aug 06, 2009 | Honeywell Heating & Cooling
Honeywell Chronotherm III is stuck on Repl Batt
when i have seen this in the past, i have been able to clean the contacts that the batteries touch.they may not look dirty, but if they get a little corrosion or get tarnished, they will not let the full battery power get to the stat and it will think the battery is low. try cleaning it with some emery cloth and see if that helps.
Jan 12, 2009 | Honeywell Power Humidifier: Furnace...
Change battry
I don't believe that the cell unit can be changed. It is rechargeable, so if it is not recharging it is probably kaput or your cord needs to be replaced. I looked through all the replacement parts for your shaver and there is no battery available. Here is an address where you can find a place to have it service if you want to or at least speak to someone regarding the shaver.
http://www.braun.com/na/contact/servicepartners/americas.country.html
thank you for using Fix Ya and Good luck to you.
Aug 22, 2008 | Braun Flex Integral 6550 Electric Shaver
Don't know how to get my battery out of my sidekick II?
The device does not contain a user repl battery.The batt is rechargable and is recommended that you charge it nightly.It uses an internal lihtium ion batt.They say contact cust care due to fluid that may leak from the internal batt can result in injury to skin and eyes?? Theysay cust care for assis if you need repl batt.http://www.wirefly.c...
Jul 26, 2008 | T-Mobile Sidekick II
Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Jul 11, 2008 | Braun Flex Integral 6550 Electric Shaver
Braun Flex Integral 6550 Electric Shaver Logo
47 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
