Question about Candy FP855 Electric Single Oven
Candy f331 oven
I have a candy f331 oven and the oven wont work when i switch on at wall. The display does not flash as it is supposed to. I have to leave it for 5 or 6 mins until it does. Then when oven goes on it lasts for a matter of seconds before switching itself off. Can you help please
Bruce
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Posted on Feb 22, 2010
Testimonial: "GR8 JOB HAVE ALREADY SEARCHED ON THE NET BUT THIS CONFIRMS. NICE ONE CHEERS."
Both fans on Candy R43/3x do not work Everything else is working
There are three switches that can have an impact on the correctness of the circuit with both fans. I think it is incorrect change over switch (pos.90) because contacts P3-5 and 4-P2 are its integral part. I believe that the TS (Safety thermostat) is correct because as you indicated "Everything else is working", otherwise would not work anything. Also, always check the wiring.
25668012-mrjy53zcgwxpbb2ywrvt3vof-4-10.jpg 25668012-mrjy53zcgwxpbb2ywrvt3vof-4-15.jpg
Dado
Apr 27, 2015 | Candy Ovens
I have a Candy TCP21x oven and the bottom fan oven has stopped working as well as the digital display, the top oven still works. Any ideas?
problem with the board.. is it under warranty? Have tech get replacement if it is. May have to pay labor.
Nov 19, 2014 | Candy Ovens
Oven is not working its 5 years frigdare electronic elements are ok
Try setting clock before presuming board is faulty, ovens shouldn't work if clock is flashing or timer is counting down or bell symbol flashing. Consult your instructions
warmest regards
Richard The Repairman
Mar 29, 2014 | Frigidaire FEB30S5D Electric Single Oven
Aeg competence d8800 5
Electronic component failure. As only 5 years old then worth calling a Service Engineer.
Sep 18, 2017 | Ovens
Smeg SD012 top oven failed
Is the clock set to auto and not manual? Is the clock display flashing? If so then set to manual, this should do the trick
Jan 17, 2014 | Smeg Ovens
My candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Mar 28, 2010 | Ovens
CANDY OVEN
Feb 22, 2010 | Candy F248P Electric Single Oven
Volume control candy oven timer
Switch off the oven, leave for 5 seconds and switch it back on.
Candy Customer Services asked for over £100 to have an engineer sent to my house, which I refuse as I thought the oiven was good.
I had to switch off all the electricity in the kitchen but after this 'reset' the oven turned to the normal 'high' volume.
Jan 12, 2010 | Candy Ovens
Whirlpool electric oven
hi switch main power off at wall. hold middle clock button in and switch power back on at the wall. Display should show --:-- and oven should work.
Nov 30, 2007 | Ovens
Candy FP855 Electric Single Oven Logo
Top Candy Ovens Experts
ashburton
ray gallant
Gaark
Are you a Candy Oven Expert? Answer questions, earn points and help others
