Question about Jetway P4MVMP Motherboard
Does it matter which direction the pins are connected to the motherboard for the cables?
  • 31 Answers
Yes it does, in most cases the words on cables point up, towards the top of the case
Posted on Jan 26, 2009
  • Jetway Master
  • 4,806 Answers
Yes it does.
If you backwire the devices you could damage them if you wire them up wrong
How to conect front panel
For this you need the motherboard manual.
If you do nor have it, download it.
The setup procedure will be at the beginning, after the specifications. The two cables from the front panel that are important are the (power on , LED reset) cable, and the USB cable.
Both these cables are built to the Intel developed, case standard, on most PCs.
The problems start when you are building a PC with an old case. The wires from the front panel will be all separate.
The motherboard manual will have the location of the pins, and the "pin out" for the motherboard.
The color lead is positive, and the white is negative.
The speaker wires are red and black, and the polarity does not matter.
Do them one at a time. Start with power on, when you have found the proper pins and hooked up the leads, then reset, then power LED, then HDD LED, and last the speaker.
Then find the USB pins and connect the USB cable to the motherboard.
The PC should boot, assuming the other components are installed.
Sep 02, 2015 | Computers & Internet
Power supply diagram for ht 2000 motherboard
http://www.ebay.com/itm/ECS-HT2000-AMD-AM2-Socket-mATX-DDR2-800-Motherboad-w-NVidia-Graphics-/251260314586?pt=Motherboards&hash=item3a804823da
1) Uses one 24-pin ATX main power cable.
Motherboard installed in computer case, the motherboard connector for the 24-pin ATX main power cable; is to the Right of the Blue IDE (PATA) connector.
(Right side of motherboard)
General example. Note that color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) Uses one 4-pin ATX +12 Volt power cable,
Motherboard installed in computer case, the whitish square 4-socket hole connector, to the Bottom/Left corner of the Processor socket; is the 4-pin ATX +12 Volt power cable's motherboard connector.
General example. Note color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
THAT, would be considered a Power Supply diagram of the motherboard.
They are the only two power cables that plug into the motherboard.
The front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Power On switch, Power On LED, (Light Emitting Diode), Harddrive activity LED, and a Reset switch IF used.
Regards,
joecoolvette
Apr 15, 2013 | ECS HP MCP61PM-HM Nettle3-GL8E 6150SE AM2...
Need wiring diagram for a hp m7680n
The good thing about the power connectors is they only fit where are supposed to fit. Either they do or the don't. There may be only three that are special. A 24 pin motherboard, a 4 (2x2) or 8 pin supplementary, and a flat 4 pin for a floppy drive. The rest are for SATA drives and the numbers really don't matter. Plus spares for possible expansion.
This is the manual.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00748726&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3230688#N326
Oct 13, 2012 | HP Pavilion Media Center TV m7680n PC PC...
Gateway dx4822-01 power supply
Gateway DX4822 Desktop PC,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2291
Just a regular Ol' ATX power supply. Rated at a maximum wattage rating of 300 to 525 Watts. Two different power supply options offered.
Power Supply case size is;
6 Inches Wide, by 5-1/2 Inches Long, by 3-1/4 Inches Tall. (152.4mm Wide, by 139.7mm Long, by 82.55mm Tall )
Has the following power cables;
A) 1 -> 24-pin ATX main power cable,
[ NOTE* Color of connector on power cable, OR motherboard, does NOT matter.
Proper connector, proper power cable, DOES matter; connector color does not matter ]
B) 1 -> 4-pin ATX +12 Volt power cable,
{ Power to the motherboard, and all components connected to it }
C) 2 or more -> SATA power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
{ Power to a SATA harddrive, and/or power to SATA optical drive/s.
(CD/DVD drive) Or power for an upgrade in the future, for a SATA optical drive }
D) 3 or more -> Standard 4-pin Peripheral power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
{ Power for an IDE (PATA) harddrive, or drives. Also power for IDE (PATA) optical drive/s. Plus power in some instances, for computer case fans }
E) Two or more Small 4-pin Peripheral power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
{ Listed as a Floppy Drive power cable. Back in the day when the article was written, such was true.
It can still be used for a Floppy Drive, but is more used now as a power cable for a;
1) Card Reader.
2) Computer case fans (IF needed }
It's name is Small 4-pin Peripheral power cable. It is smaller than it's larger cousin, the Standard 4-pin Peripheral power cable.
Also has smaller gauge of wiring. This means it cannot carry the same amperage, as the standard 4-pin Peripheral power cable.
I would recommend this,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899124&CatId=1483
A) 1 -> 20 + 4-pin ATX main power cable.
Can be used as a 20-pin ATX main power cable, or a 24-pin ATX main power cable, which is what you need.
B) 1 -> 4-pin ATX +12 Volt power cable.
C) 6 -> SATA power cables
D) 4 -> Standard 4-pin Peripheral power cables
E) 1 -> Small 4-pin Peripheral power cables
F) 1 -> 6-pin PCI Express power cable
G) 1 -> 6/8-pin PCI Express power cable.
In the future, (Or now if you have one), you can upgrade to a better graphics card, that needs an additional power cable, IF you wish.
The 6-pin PCI Express power cable.
You also have a 6-pin or 8-pin PCI Express power cable.
(6/8-pin PCI Express power cable)
All the pins can be used together, and make an 8-pin PCI Express power cable, for a very powerful graphics card that requires this cable.
Just added bonuses with today's modern power supply's.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 04, 2012 | Gateway DX4822-01 Power Supply 575 Watt...
Installed new power supply on hp m470n cannot remember which wires go where HELP
The large power connector goes onto your motherboard--20 or 24 pin--in the socket provided. It can only go in one way.
There is probably a second connector, a 4-pin--that will plug into the motherboard near the CPU. It, too, can go in only one way.
Other than that, you just have to hook up the power to the hard drive and CD/DVD.
If you have a high-performance video card that has a power connection, it's probably a 6-pin connector.
var fctb_tool=null; function FCTB_Init_1fa6d7a6c9664247a0ca49a75c796f65(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_8ff702f2dff743098e4136310439f4e3(t) { fctb_tool=t; start(fctb_tool); }
Nov 13, 2010 | HP Computers & Internet
I would like an internal view of eMachine T4150 to be sure everything is connected correctly
I could not find an internal photo with everything connected but I could find a picture of the motherboard but it was very small. Just make sure your graphics card is inserted fully into AGP slot, processor is clipped down, memory is clipped down, and your hard drives are on one IDE ribbon cable and your rom drives are on the secondary IDE channel. (jumpers are correctly set to Master/Slave). Then make sure the CMOS jumper is set correctly and check the button cell battery for the CMOS clock. That's it
Mar 09, 2010 | Computers & Internet
I need to connect a new Antec 380d PSU to a A7v333 And connectors are different any suggestions?
The Antec 380D PS comes with an ATX 24-pin main power connector. If you look closely you'll see the extra 4-pin adapter is for motherboards that use all 24-pins. Your board needs only 20-pins. The extra 4-pin connector can be disconnected from the main cable & is not used.
Looking closely at the A7V333-X's main motherboard ATX power connector (On the board). The power connector has a locking tab on one side of the port. (This locking tab faces the memory).
This insures that you connect the power cable in one direction only. The Main power cable also has a locking tab attached to it and the two tabs lock together. See page 1-3, number 4.
Cheers!
Mike
Dec 29, 2009 | ASUS A7V333-X (A7V333-X/L) Motherboard
Sound card pin in the motherboard
To identify the solution of front panel of audio code,note that AC97 and HD audio devices are different,and may not be directly compatible.If there is a cable connected to the pin 4 then it is HD audio.If there is no cable connected to pin 4 then it is AC97.
Dec 17, 2009 | Intel D850MV Motherboard
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
I can't find how to connect my dvd writer to the Asus Rampage II Extreme motherboard. The missed pin in the connection cable is in a different location
If you are trying to connect your DVD Writer using an IDE cable, then:
1. First, make sure that you are connecting the IDE cale in the correct direction. Make sure that the Red (or colored) wire in the cable aligns with pin 1 in the connector.
2. If the cable & connector are aligned correctly, then try to find a replacement IDE cable without a missed pin or with the missed pin in the correct position. This can cause no harm to neither the DVD Writer nor the motherboard.
Jul 11, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Jetway P4MVMP Motherboard Logo
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
