Question about Uniden QT206 Transducers
What is the replacement transducer for uniden QT206
Need replacement transducer for uniden QT206 depthsounder
  • Uniden Master
  • 696 Answers
Just about any marine chandler should be able to source one of these for you. They're made by airmar who pretty much make all marine ducers now. Here is the link to just one place you can order it.
-Steve
Uniden Nylon Thru Hull Transducer For QT206 650 5406
Posted on Mar 16, 2015
  • Steve
    Steve Mar 16, 2015
    The transducer is an Airmar P79.
2 Suggested Answers
hydetech
  • 113 Answers
SOURCE: Replacement of an old Impulse QT206
I believe it is the same model. Even if it is different, it will probably work if it has the same type of plug.
Posted on Jul 24, 2008
Best way to clean depth finder transducer
There are many websites that can tell you how to clean your transducer.
Check the link below.
-Steve
clean depth transducer Google Search
Aug 25, 2012 | Uniden Qt206 Thru Hull, Digital Depth...
I was told that the Uniden QT-206HP depth sounder will not work thru an alunium hull is this true or false
Hi!
The transducer for your depth gauge will not work through an aluminum hull. A drilled through-hull transducer or a transom mount transducer are your options here.
Just in case you require it, your Owners Manual can be viewed/downloaded at:
http://ca.binnacle.com/pdf/Uniden-QT206-manual.pdf
Hope this helps..
Jun 20, 2011 | Uniden Qt206hp Digital Depth Gauge With...
The depth gauge beeper stay on and the depth runs up and down
Check the battery power at the unit with a DC volt meter, and also use the meter's AC setting across the power post on unit. If AC volts are above a tenth of a volt, the wires to battery may be to small, not allowing enough current to drive the transducer and electronics in unit.
Aug 05, 2009 | Uniden Qt206 Thru Hull, Digital Depth...
Accurate when still display changing inaccurate
You might have air bubbles trapped on surface of transducer. Use soap on it so water sticks to surface, no wax, oil, or grease.
If transducer is mounted inside the boat, you have air trapped between it.
Jul 12, 2009 | Uniden Qt206 Thru Hull, Digital Depth...
Unit showing 88.8 in the LCD window.
Hello geld1. Your problem is the transducer, cable or connector. Check transducer with an ohm meter, flex the cable while ohming the restance shouldn't change. The location and mounting of the transducer could be the main problem. Use the the correct gel film including a secure postion support.
Sep 22, 2008 | Uniden Qt206 Thru Hull, Digital Depth...
Jul 14, 2008 | Uniden Qt206 Thru Hull, Digital Depth...
Uniden QT206 Transducers Logo
230 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Mike Marcotte
Mike Marcotte
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Uniden Boating Expert? Answer questions, earn points and help others
