Question about Dishwashers
My Hotpoint disherwasher FDM550 stops working halfway through cycle and both red lights are flashing. have checked water coming in and water going out all is ok
Machine is draining and filling ok
  • 14 Answers
SOURCE: Intake/Drain red light comes in and shuts down during wash cycle
You will more that likely have a faulty waterproof inlet system
Posted on Sep 13, 2007
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
SOURCE: candy nova cd112 dishwasher fills with water then stops working
nova cd112 this is a simple fix the machine has a electronic switch to add water to the machine it then has another switch to say the machine has water iin it , this switch is the one that is not working this is the one that turns on the element and heat the water .it costs around a tenner to replace u can find it as it is connected to the element via a wire conection .this a a common problem of over enginearing as this switch is not needed and is not on older machine .ie this switch can only come on when the machine has water in it in other words only after the switch to put water in the machine has been on.can this go on i hope u know what i mean lol. now u can replace this yourself or get an engineer it should take an engineer no more than 10/15 mins to fix better still have him bypass this switch and u will never haver the problem again as this switch is prone to going fixthis and the machine should last years no problem as its not a bad machine not quite a bosch but better than a zanussi or indicit etc hope this helps and may i just say that i tried everything including replacing the element ,stat and cpu non of which worked before realizing it was this .i must also say before u try this. Switch on your machine on put it on a universal cycle as u hear the water going in the machine open the door and add hot water as hot as u can close the door and the machine should do a full cycle including emptying and reheating the water this proves its not the cpu ,element or stat note the machine will not do the cycle without the hot water going in at the start if it does the cycle then its 100 % this switch hope this helps and sorry for the lond explantion bye
Posted on May 02, 2010
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Posted on May 29, 2010
My Servis M3001 washing machine will not fast spin , it will spin and the belt seems to be ok , the machine is filling and draining ok , can you help at allThank you
Some times on front loaders if it is out of balance it will not go into fast spin. Try to remove some of the cloths and see if this helps.
Best of luck
'RR
May 15, 2014 | Washing Machines
Water will drain durring spin cycle
This is normal on some machines. Run it through a complete cycle it should fill, agitate, drain, some will drain down so low then start spinning as it is draining but should stop draining before it fills or stops. Check if water is coming in at the same time it is draining. If not it may be ok.
Dec 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
Machine does not let the water go out
If its not filling with water then its a fill valve problem.But if the machine is filling but not draining then its a drain pump problem.Either the drain pump is clogged or faulty.Remove the drain and check both the drain pump and hose to which drain pump is connected.If both checks out ok then its faulty drain pump causing this problem.Replace the pump. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Washing Machines
Only get cold water entering washer ... no warm or hot
1. Close hot water valve behind washer.
2. Remove hot water line from washer side and place it in the drain.
3. Open hot water valve to ensure pressure and hotwater is ok in your drain.
4. If not, problem is home related.
5. If pressure and hotwater are ok, then see if your fill valve filter is clogged where you disconnected the hotwater hose attached to the machine.. Its called a fill valve. Sometimes they get clogged.
6. If the hot water side of fill valve looks ok with no blockage, then you might be looking at a new fill valve.
Feb 11, 2010 | Washing Machines
417.43142300 Kenmore drains while trying to fill with water
try this the drain hose from the washer is stuck to far down the drain .allow only 8 to 10 inches down drain if the house drain is lower than top of tub it will do the same thing. raise the drain haundi24
Oct 27, 2009 | Kenmore 43142 Front Load Washer
No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Jun 02, 2009 | Hotpoint WMA46 Front Load Washer
Washer will not start washing cycle. Machine hums like the dryer
Check the drain for clog. If the drain is dirty, the washer won't fill, rinse, or drain.
May 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine wfm 2010 not rotate just fill and drain water
sounds like the carbon brushes in motor,Or motor has had it.
Oct 11, 2008 | Bosch Washing Machines
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
