Question about Canon ImageRUNNER 330s Copier
I would like to add printer capabilities to my copy machine.
I would like to add printer capabilities to this copy machine but I'm unsure what I have to buy to add this to the machine.
  • astitchintim Jan 27, 2009
    Thankyou
  • Carlos Perez
    Carlos Perez May 11, 2010
    does the machine have ethernet port?
  • Canon Expert
  • 1,326 Answers
When you press the botton on the control that show print or scan, does it say that the copir is not equipited this funcation. If so, it will most likely cost a lot more then the whole copier is worth. The same goes with the fax funciation as well. You can most likely buy another copier with the print feature already installed. I'm sorry to say it, but you copier is out of date for printing to be afforadable
Posted on Jan 27, 2009
How should i define a printer in a wired intenet home?
Well, if the printer is network capable, it can be connected to the network router either wirelessly or wired, whichever the printer has and you wish to use. Once you have made the connection (you need to set it up with one of the computers for network use), then you can go to each of the other machines and and "add printer", looking for the network device. Each machine will detect the printer, and then load drivers to support the use. If your printer is NOT network capable, it gets slightly more complicated. You would have to install the printer on one machine, then ensure that the "share printer" option is selected. Other machines can use that printer on the network so long as the machine that the printer is attached to is powered on and on the network. They would do a search for the printer the same as before.
Nov 03, 2015 | Computers & Internet
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
How to scan double sided documents
With a home scanner you can only scan one side at a time. Some printer copiers are capable of double sided copies but the machines are big and bulky because they have to run the paper on one side then flip it over and scan the other side. These type machines are for office use. What kind of scanner are you trying to use? Is it the Lexmark as listed, if it is then it is not capable of scanning double sided documents. they must be scanned one page at a time.
Oct 01, 2011 | Lexmark Prestige Pro 805 Color All-in-One...
Can i make copies witht he brother hp 2040 printer
A printer would produce print outs of documents in versions known as hardcopies(paper). However, multifucntion devices usually would have an area on the printer that allows to feed in an aready printered document to be reproduced several times into several hardcopies(paper copies). Unless that, the printer has multifunction capabilities, in which instance would be in writing specified as capable of performing printing, copying and several feature functions, it would be unlikely to perform copies from an already existing document.
Jan 11, 2011 | Brother HL 2140 Laser Printer
DOES THE MACHINE HAVE FAX CAPABILITIES? DO YOU
No. They have print,scan and copy capabilities but no fax option is avail.
Dec 17, 2009 | Canon imageRUNNER 5000 Copier
When printing or copying I m getting thick black
First try running maintenance to clean print head on your machine.
If that does not solve your problem replace the ink carts OR Toner cart.
(I am unsure which you have as that was not specified)
Jun 08, 2009 | Brother DCP-8060 Laser Printer
My printer works but my scanner doesn't
Do one thing, remove the software from control panel add/remove programs. Then reboot the machine. Put a CD again, connect your all in one and run the setup.
Apr 03, 2009 | Office Equipment & Supplies
Unable to copy dvd's
Most dell machines do no come with dvd rewriting as standard. They only come with cd rewriting capability. Unless you specifically requested it as an add on to the spec it probably just has the ability to pay dvd's.
Most internet cafe's will have a machine with a dvd rewriter if you really need to copy a dvd
Val
Dec 15, 2008 | Dell Inspiron 6000 Notebook
Copier
Hello oldray,
If we are talking about the same model which is Lexmark Z25
Color Jetprinter, it is a simple jet printer and does not have copy machine capabilities. Hope this helps clarify. Let me know.
cancerags
Nov 14, 2007 | Lexmark JetPrinter Z25 InkJet Color...
52 people viewed this question
old marine
old marine
