Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub cadet starter won't turn engine over
Solinoid engages but won't turn over engine
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
SOURCE: My cub cadet zero turn mower won't engage the
I have a cub cadet zero turn 50' mower, i start mowing and after about 10 minutes it starts running out of gas, i pull out the choke to keep it going but it just keeps getting worse to the point of quitting. If i slow it down to a idle or just a little more it will stay running but that is not fast enough to cut the grass. does anybody out there know why i am runnung out of gas. I put a new filter on it, It did not help.
Posted on Jun 20, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
  • 109 Answers
SOURCE: my cub cadet won't start the info panel says pto
disengage the pto switch...
Posted on Jun 30, 2009
My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Apr 17, 2013 | Garden
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
I HAVE A CUB CADET LT1050 LAWN TRACTOR AND WHEN I TURN THE KEY I GET ONE SINGLE CLICK. THE STARTER DOESN'T ENGAGE
Hi camy wils815...
Sounds like you have a faulty solinoid.
Make sure your battery has a full charge, the by-pass the starter solinoid on the engine.
To do this ground one big wire connection to one of the small wire connectors (with the wires still hooked up) and if it starts, then replace the solinoid...if it does nothing, replace the solinoid.
Please take time to rate me
Jul 30, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have a Cub Cadet 2166 . When I try to start it, the starter drive throws up, but won't turn the engine. I took the starter off and when you turn the key to start, the drive throws up and turns slow...
Can you measure the voltage of the battery? If you are getting low voltage then the battery needs to be charged or replaced, if the voltage is good then you probably have a bad starter. It might be something you can see like shorted windings on the motor.
Jun 07, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I need a wiring diagram for a 3165 Cub Cadet Lawn tractor. I need to know where the 2 green wires in the wiring harness go.
My name is Dane and I am going to try to help you solve your problem. Here is a link to where you can find your 3000 series manual. The wiring schematics start in chapter 13.
http://www.mymowerparts.com/pdf/Cub_Cadet/Cub_Cadet_Service_and_Repair_Manuals/
I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
Dec 04, 2010 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub Cadet 1641 won't start....
sounds like the battery doesn't have enough power to crank the engine
May 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
May 02, 2009 | Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
108 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
