Question about Acer X191WSD Monitor
Acer x191w monitor background is moved to the right with about 2inches of black on left side.
I tried the horizontal and vertical adj.on the monitor but it won't move it far enough left. Thanks for any help!
  • 2 more comments
  • gove scrivenor Jul 20, 2007
    unfortunately it didn't work.... i sure do appreciate your effort!!
  • Anonymous Mar 10, 2008
    same thing happened to me. on my laptop, when i pressed the auto and menu buttons together, it fixed itself. with my desktop, this would not work. i think that's what caused the problem in the first place. not sure, though. the changing resolution solution offered by one poster is useless. he doesn't understand the problem
  • MG_Eagle1 Jul 28, 2008
    Resolution wont go higher than 800 x 600.do i just need to d/l a driver?
    please help
    thanks
  • pyt76 Aug 31, 2008
    same thing happened to me when I switched to an acer monitor from a different monitor-didn't have this problem on the other one.
    New Friend:
Here is the fix;
1. Go to Screen Resolution
2. Select Acer Monitor
2. Find Advanced Settings and click
3. Find Screen Refresh Rate and change it to 75Hz
4. After the monitor flicks, changes it BACK TO 60Hz.
This fixed the problem for me. Hope it helps. :)
Posted on Apr 01, 2013
I tried this and it still does not fix my problem. I went into Menu and hit reset by mistake and that totally screwed up my monitor. Now the left side gets cutoff and no matter what I change the resolution to it does not fix it.
Whjat should I do?
Posted on Apr 15, 2008
I had the same problem. i think it was caused by pressing the auto and the menu buttons at the same time. doing this again fixed the problem on one computer, but not on the other. changing resolutions has nothing to do with it.
Posted on Mar 10, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 25 Answers
Try changing your screen resolution settings. You may do this by RIGHT clicking on an open area of your desktop, select the PROPERTIES option from the dropdown menu, click on the SETTINGS tab, then adjust the SCREEN RESOLUTION slider in the bottom left of the box until you get a setting that returns your screen to normal. Hope this helps!
Posted on Jul 18, 2007
My Acer monitor has 3 inches missing on the left side and 3 inches black on the right
There should be buttons somewhere on your monitor...one named 'Menu' there you should click on an option to change the positioning or horizontal/vertical then follow the instructions...usually the arrow keys...to move the frame to where you need it...hope I helped!
Jan 13, 2015 | Acer 22" X223w LCD Monitor
...hi, i've got a 2" wide black vertical area on
That reads like an alignment problem on the monitor, rather than a computer setting.. If you have a flat-panel monitor, usually on the front, lower right or along the right side, you can press a Menu or Settings button, press + or - to the Horizontal setting, press the Select button, then press the + or - button to move the display to the right. Press the Select or Menu button again to set the new location.
The actual button designations could be different.. best if you look at the manual on the monitor.
If graphics card will let you oversize the display, it might also have a Pan option that would let you slide the display back to the right. In that case, look in the Notification area (lower right) of the screen for a graphics card icon that will let you Pan right.
Oct 30, 2013 | Computers & Internet
Need driver for Acer x191w moniter
http://www.nodevice.com/driver/X191W/get72415.html
get the monitor driver from this link.
You just have to put the code in the bottom of the website in above link and download it.
best of luck!
Mar 12, 2012 | Acer Computers & Internet
My new LG Flatron E2350 does not fill the 23 inch screen only 22 inches with a black border, have updated graphics and monitor card to the latest. What do I need to do for the graphics to fill the 23 inch...
Similar to TV - you need to adjust the "H" - Horizontal and "V" - Vertical. Horizontal will move picture up or down and Vertical will adjust left to right.
Use the menu button on your monitor.
Apr 03, 2011 | LG Flatron L1515S 15" LCD Monitor
Monitor's display is shifted up and right so that there is just black space to the left and all along the bottom whereby cutting off the display. cannot see bottom menu bar.
One of the buttons on the front of you monitor (bottom right hand corner of the bezel) is a menu button. Press that then using the the arrows up and down buttons go the the horizontal and vertical positioning option. Once chosen move the display as desired.
You could also press the Auto (config) button, that may do the same for you.
May 17, 2010 | Acer AL1912 19" LCD Monitor
Al2016w horizontal wont adj. enough
what is this your monitor,LCD or CRT monitor?thanks
Jun 10, 2009 | Acer AL2016WBbd Monitor
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Desktop is dispalyed horizontal on monitor
The Ctrl-alt direction key sequence is supposed to be used for changing your workspace. On my computer at work it changes the screen orientation Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
(If that doesn’t work, try Ctrl-Shift-R)
May 31, 2008 | Acer X193W LCD Monitor
No horizontal red convergence control
Probably the red convergence output IC has failed. The chip is basically a stereo amplifier that serves as a horizontal amplifier and a vertical amplifier. I suspect the vertical part has failed and is not uncommon. Should be generic STK392-150's or maybe STK392-110/120 I believe. By the way when the line moves up and down that means the vertical is working when it moves side to side the horizontal is working.
Feb 03, 2007 | Philips 60PP9202 60" Rear Projection...
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
Acer X191WSD Monitor Logo
1,005 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
