Question about HP Photosmart 2610xi All-In-One InkJet Printer
2610 xi HP printer will not print, copy or print a FAX
If it needs a cartridge or printer heads, I don't know where they are.
  • just4you Mar 11, 2009
    I recently moved my computer and now it want print. I sometimes can get a blank sheet of paper to come out. I have checked the connections and they seem fine.
I recently moved my computer and now my printer dosen't work. I have checked the connections and they seem to all be fine.
Posted on Mar 11, 2009
  • 628 Answers
Lift up the part under the glass and you'll find the print cartridges. Just lift up and pull out.
Posted on Jan 26, 2009
Hp officejet 4620 does not print with starter cartridge
If printer is in warranty, demand for replacement.
1. Check ink levels in printer..if levels are showing, take out all ink cartridges refill them.
If levels are zero, go for new cartridges.
2. If ink level are showing in printer & physically cartridges having ink, then problem with print head, try to clean the clogged nozzles.
Nov 16, 2014 | HP Officejet 4620 e-All-in-One Printer,...
I have changed the cartridges several times and use the 920
the problem could be with print heads not in cartridges
try to replace print head it one part
Sep 24, 2013 | HP Officejet 6500A Plus Wireless...
My 2610 prints with ink streaks even with new cartridges. What's the likely fix?
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts or possible fault of the printing head.
Sep 26, 2010 | HP Photosmart 2610 All-In-One InkJet...
No print on copies or faxes
This is a clogged print head. This happens if the printer has been off for a long time or if the cartridge was removed and the unit left empty for any time.
Take out the cartridge and press the print part on a piece of paper. Any black lines? If not, you will need a new cartridge. Wiping the print head gently with a Q-tip moistened with PURE alcohol (99%) may restore printing.
Mar 31, 2010 | HP 1040 Plain Paper Inkjet Fax
Have not used the 2610 for about a year. when copying, page is blank. Think its dry ink cartridges? Or maybe something else?
hello, mostly likely your guess is right INK is dried up.
You can try to use the HP utility to clean print head, you probably installed this with printer when you first set it up,
if you don't see it visit hp site and download the software here;
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=421139&lc=en&cc=us&dlc=en&lang=en&cc=us
if this doesn't work change cartridges.
good luck, hope this helps
regards
Amar Sondhi
Dec 04, 2009 | HP Photosmart 2610 All-In-One InkJet...
Photosmart 2610 with power on get Error 0x886a6916
0x error codes indicate that the product has an internal error. Try to reset the printer:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Hp 2610 will not print black even with new cartridge. HELP
Try cleaning the gold contacts on cart first, with distilled water. Let dry and try again.
If not, try this one
1.Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Inkypete
May 24, 2009 | HP Photosmart 2610 All-In-One InkJet...
How do i change font size on HP 6110 xi printer
The manual doesn't list scaleable font size as a feature. You will probably have to set your font size in the document you are making.
Mar 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP Photosmart 2610xi All-In-One InkJet Printer Logo
85 people viewed this question
Ben Johnson
